DA0R53MB6E0 overheat issue & power off
  • rookieme
    • Oct 2014
    • 397
    • Greece
    I'm having an issue with this board as it overheats [within seconds] the cpu and powers off after some minutes.
    I'm not sure if this is a heatsink issue as it is clean and the fan spins like crazy [heatpipe burns fingers but exhaust doesn't].
    There is a chance that the heatpipe solder is failing but I'd like to ask if it could be the processor as the cpu core voltage is 1,29V [PL20 & PL21] which is arranged by isl6277 at the voltage cpu asks for.
    So 1,29V is normal for cpu voltage at bios menu?
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    Hi everyone,
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    Diagnosis showed PP1V5_UPC0_LDO_CORE shorted to ground.
    I replaced U3100 (UF400) using a donor board (A2179), and the machine powers on fine now.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • ugamazing
    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
    by ugamazing
    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
    12-17-2024, 07:05 PM
  • ahmarzo
    Acer laptop battery draining issue
    by ahmarzo
    Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
    Help me to diagnose this issue as there is no shortage in the inputs MOSFET
    08-02-2025, 06:39 AM
  • elmark
    HP 15-cw1002ua strange keyboard issue
    by elmark
    HP Pavilion 15-CW1002UA
    S/N 5CD0251CBC
    P/N 7KE54EA
    Hello guys!
    I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
    It powers on OK and has no other issues except the following:
    • CAPS LOCK does not work at all
    • Fn button toggles Flight Mode
    • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
    • (with SHIFT pressed: 't%' and 'y^' respectively)
    I initially thought it was a keyboard malfunction (internal short, etc.),
    but when I press and hold...
    06-27-2025, 01:10 AM
  • Simone Vergani
    Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
    by Simone Vergani
    I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
    To assist with troubleshooting, I'm attaching two power circuit schematics:
    • Power
    03-05-2025, 02:25 PM
