NAD T753 receiver repair, dead after storm, shorted microcontroller ALI M6759
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This sucks, I know.
    This complex and crappy receiver is dead after a storm. There's voltage coming out from the standby tansformer, but it's just 5V instead of 13V. This goes to Front board and then to Main, where voltage regulator U704 produces 5V for microcontroller. But then I see that 5V rail in front board is shorted! Disconnect board completely and apply external 5V to it, with some alcohol on top of every IC that eats 5V. U202 heats very quickly. This is an ALI microcontroller M6759, PLCC 44pin package. No external Flash or ROM, so its program is in internal flash.
    The big problem is, of course, how to program that IC internal flash. Local NAD distributor says that the part is obsolete. I don't have the memory dump and I doubt anyone will have it. Since original IC is shorted it's impossible to retrieve its content.
    Any idea?
  • mmartell
    • Oct 2013
    • 3189
    Re: NAD T753 receiver repair, dead after storm, shorted microcontroller ALI M6759
    Have to find one from a donor machine I would say.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Here is the service manual
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Wonder if this is and equivalent?
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          Here is the Data sheet for the micro controller you are looking for
          • Chungalin
            • Jul 2014
            • 423
            • Spain
            Thanks, I already had these documents before posting my message. As I tried to explain, the problem is that I don’t have the data file to program these microcontrollers. Even if I had the firmware file, I think that it wouldn’t be easy to setup the wiring and protocol from scratch.
            Luckily I’ve been able to contact NAD main distributor in Spain and he’s offered me the microcontroller pair (U201 and U202) for a price that is not cheap neither too expensive. I’ve agreed and now I’m waiting for the parts to get here. I’ve made clear that the ICs have to come properly programmed with the right firmware.
            Will report progress.
            • Chungalin
              • Jul 2014
              • 423
              • Spain
              I received the pair of controllers last friday, I replaced them and now it works fine. They (NAD representative in Spain) sent me the U201 ("AVR") and U202 ("VFD") programmed with firmware version 2.12a.
              • Chungalin
                • Jul 2014
                • 423
                • Spain
                This story hasn’t ended yet. The amp works fine in analog mode, all 7 channels, even video is okay, but when I wanted to use digital inputs I found that it was impossible to switch Surround Mode, it always said HEADPHONE on display and stayed in Stereo mode.
                Checked again all connections that I touched on first repair and everything was fine. Then I noticed that optical TOSLINK output socket wasn’t emitting red light. This comes from a 74HC251D multiplexer (U1203) that selects one from 6 digital inputs. It’s partially shorted! I’ve ordered another one.
                Remember that this was a storm failure, so it was too good to be true that only microcontroller was hit. Since there was a DVD connected to one coax digital input, there’ll be chances that it has dead digital output too.
                • Longbow
                  • Jun 2011
                  • 623
                  I think this is how we all learn to respect the power of lightning and/or power line surges. The basic rule of thumb here is that lightning doesn't break just one IC. Parts unit.
                  Is it plugged in?
                  • mmartell
                    • Oct 2013
                    • 3189
                    Don't count him out yet, sounds like he has a handle on it.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Originally posted by Chungalin
                      Thanks, I already had these documents before posting my message. As I tried to explain, the problem is that I don't have the data file to program these microcontrollers. Even if I had the firmware file, I think that it wouldn't be easy to setup the wiring and protocol from scratch.
                      Luckily I've been able to contact NAD main distributor in Spain and he's offered me the microcontroller pair (U201 and U202) for a price that is not cheap neither too expensive. I've agreed and now I'm waiting for the parts to get here. I've made clear that the ICs have to come properly programmed with the right firmware.
                      That is how they make the money to pay the programmers and engineers. Otherwise, I think they could program it over the internet without having a chip programmer.
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        This story hasn't ended yet. The amp works fine in analog mode, all 7 channels, even video is okay, but when I wanted to use digital inputs I found that it was impossible to switch Surround Mode, it always said HEADPHONE on display and stayed in Stereo mode.
                        Checked again all connections that I touched on first repair and everything was fine. Then I noticed that optical TOSLINK output socket wasn't emitting red light. This comes from a 74HC251D multiplexer (U1203) that selects one from 6 digital inputs. It's partially shorted! I've ordered another one.
                        Remember that this was a storm failure, so it was too good to be true that only microcontroller was hit. Since there was a DVD connected to one coax digital input, there'll be chances that it has dead digital output too.
                        If it was not a direct strike on the transformer or electrical line and your power section was not affected that is a good thing.
                        So that only leaves the cable line. I do not know over where you are at, but in the US I know Comcast has a box just for this problem. It is a whole box just to protect the cable line lighting strikes.
                        • Chungalin
                          • Jul 2014
                          • 423
                          • Spain
                          88€ was the total price for the µcontrollers pair +S&H. The most expensive part I’ve paid this year, for sure. 90% of this price is for programming the firmware.
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            Yea, that is a lot of money. Still it is cheaper than a refurbished unit or a new one. I guess it depends on how much you enjoy music from it and if you can afford it. Personnel I like a two channel stereo with an A/B Amp.
                            • Chungalin
                              • Jul 2014
                              • 423
                              • Spain
                              Me too, but this is work, it's not mine. I'd never buy a monster like this. I feel dizzy when I see one of those receivers with countless RCAs, HDMIs and speaker clips on back panel.
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                Ahh work. These companies need to give you better tech support. It gives them people who are willing to understand and repair their product without the cost associated with an employee. It also would give their customers a quicker turn around making the customer happier. A happier customer brings in more customers and return customers. But they just want everyone to fill up the landfill with their junk so they can make more and more of your money. The problem with that is eventually the well runs dry and you end up with many poor people and very few rich ones. At this point usually a bloody revolution happens.
                                • battlecat
                                  • Mar 2010
                                  • 18
                                  • South Africa
                                  Hi Chungalin..
                                  Is there any change you could forward the details of the supplier for this chipset for the NAD T743 ?
                                  Same thing happened , lightning storm and nothing was plugged in... I noted the post was in 2014 , but taking a chance here..
                                  NAD support in South Africa went for runner.
                                  School fees paid as everyday is a learning curve.
                                  • Chungalin
                                    • Jul 2014
                                    • 423
                                    • Spain
                                    I ordered the part from spanish NAD representative, and they ordered it from NAD Canada.
                                    I still have it sitting here, because lightning damaged something else in digital board and I found too overwhelming to face it. I had the hope that only digital input multiplexer was damaged, but now it works OK and still cannot detect any digital input. Definitively my most frustrating repair of 2016.
                                    • CDNBrewer
                                      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                      by CDNBrewer
                                      Hello Everyone,
                                      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                      Symptoms:
                                      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                      • I swapped the Left and Right surround
                                      08-05-2025, 09:29 PM
                                    • wolf1976
                                      wireless receiver for 6 speeds fan control with remote control
                                      by wolf1976
                                      hi i have a receiver that is destroyed from the overvoltage i guess
                                      my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                      the motor fan has not label
                                      i have an other receiver operational
                                      In your opinion can i measure the voltage at the output ?
                                      what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                      thanks in advance...
                                      07-23-2025, 03:12 PM
                                    • CdDvdFlash
                                      DSE GE6878 possible TV receiver dying remote not working well
                                      by CdDvdFlash
                                      For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                      07-03-2024, 03:55 AM
                                    • sanalelevenstar
                                      Yamaha RX-V485 receiver. After encountering a "version error"
                                      by sanalelevenstar
                                      Hi everyone,
                                      I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                                      After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                                      I managed to find the service...
                                      09-10-2025, 01:54 AM
                                    • Cornito
                                      Denon AVR-2700H audio stops while receiver still works
                                      by Cornito
                                      Hello team,
                                      I've got a new issue with a Denon Avr-2700H.
                                      After several minutes working, receiver stops playing sound with a poc eared in the speakers.
                                      Receiver still work and display video with error message on display.
                                      Seems to me that is the main output relay.
                                      I'm looking for the service manual that I can't find for the moment.
                                      Does somebody have it?
                                      Regards...
                                      08-03-2025, 06:10 AM
