is this Transformer good or corrupted? TM-09180 TNE 1046 DT
  • mikail13
    • Aug 2013
    • 93
    • Turkiye
    SAMSUNG P2270HD tv's symptom is 2 second to black..
    Trnasformer is TM-09180 TNE 1046 DT
    i measure the pins with multimeter.
    there is no signal at opposite positions. i. e 1-2 3-4 5-6 7-8 1-4 1-6 ..
    others at pic..
    please help..
    Re: is this Transformer good or corrupted? TM-09180 TNE 1046 DT
    How come the transformer winding resistance readings are showing in V (Volt)?
    • diif
      • Feb 2014
      • 6978
      • England
      I've just changed a TM-10160 in a Samsung T260 today.
      You need to measure the resistance between pins 2 and 4 and also between 6 and 8.
      • mikail13
        • Aug 2013
        • 93
        • Turkiye
        thanks for help..
        2-4 1810 ohm
        6-8 1080 ohm
        front of board is https://www.badcaps.net/forum/showthread.php?t=56519
        4-6 = R301 is 199 k Ohm
        • diif
          • Feb 2014
          • 6978
          • England
          The resistances should be very close, which they are not. Suggests the transformer is faulty.
            +1, you have bad transformer. The reason for bad winding can also be due to bad lamp drawing too much current, so when you install the new one you should check the temperature.
            • mikail13
              • Aug 2013
              • 93
              • Turkiye
              +1
              thanx
              you're right. today i measure old Philips 170S 's transformer and see same number.
              because of transformer bad machine shuts in 2 second..
              i think this is suitable..
              https://www.aliexpress.com/item/1pcs...208.8.8.NZaJsF
                I hope the shipping will be a lot less shipping to your country.
                EBAY has them too.
                • mikail13
                  • Aug 2013
                  • 93
                  • Turkiye
                  no.
                  shipping is only 1,89 $ .
                  it's weird that 2-4 are 5800 ohm after the 2 caps desoldering and resoldering,
                  at new one
                  2-4 1134ohm
                  6-8 1140 ohm
                  Problem solved. Thank you very much indeed.
