Panasonic CF-C1 BIOS
  • diif
    • Feb 2014
    • 6978
    • England
    I'm looking for a BIOS dump for this Panasonic CF-C1 if anyone has one.
    Thanks.
  • Meck
    • Jan 2015
    • 5
    • Bosnia
    Re: Panasonic CF-C1 BIOS
    i have cf c1 mk1 but i need mk2 did have sameone ?
    • rioreno
      • Feb 2009
      • 540
      • Indonesia
      whats problem with your bios cf-c1-mk2? can you post your old bios?
      • diif
        • Feb 2014
        • 6978
        • England
        It's password locked. I can read it if that will help, I will need to disassemble the laptop first though.
        • rioreno
          • Feb 2009
          • 540
          • Indonesia
          for cf-cf1 mk1 i'm sure it can be remove the bios password,you can get your file from panasonic.. but for cf-c1-mk2 there is no update file...
          this is for your bios diff (cf-c1-mk1)
          but you need to fill dmi by your self..
          better your try..
          goodluck
          eeh, btw your type mk1 or or mk2??
          • diif
            • Feb 2014
            • 6978
            • England
            Thank you. I will dig it out later and let you know.
            • stefanciprian
              • Feb 2017
              • 1
              • romania
              better your try..
              goodluck
              Thank for this dump!
              • jfpico
                • Dec 2017
                • 10
                • españa
                Hello, my English is very bad.
                I have a cf-c1 mk2. with bios passwords. I already have the dump of this team. can I remove the passwords by modifying the dump file?
                Or look for a file without passwords would be enough. Thank you.
                • jfpico
                  • Dec 2017
                  • 10
                  • españa
                  This is my dump bios with passwords. in case someone knows how to remove it.
                  • rioreno
                    • Feb 2009
                    • 540
                    • Indonesia
                    try this...
                    goodluck and please confirm...
                    • jfpico
                      • Dec 2017
                      • 10
                      • españa
                      try this...
                      Thank you very much. on Tuesday I try it and I assure you that I will post with the result. I am incredibly surprised by your speed.
                      • jfpico
                        • Dec 2017
                        • 10
                        • españa
                        Hello, I've tried it and it does not work. does not turn on the computer.
                        • george_gpu
                          • Dec 2015
                          • 77
                          • greece
                          good day
                          i need help , i need bios rom for panasonic cf ax3
                          • jfpico
                            • Dec 2017
                            • 10
                            • españa
                            In the end I bought a second-hand motherboard and extracted the bios and it works ok. Here I leave the dump of CF_C1 mk2. without passwords.
                            • VFR3000
                              • Mar 2018
                              • 1
                              • United Kingdom
                              Hi Anyone know what mk this CF-C1 is?
                              Model Number: CF-C1KT01GGE
                              MANY THANKS
                              • xzm
                                • Feb 2011
                                • 28
                                MANY THANKS
                                This is mk1 type, because if is after CF-C1 "K" or "A", then is this mk1 type.
                                • ceosmihail
                                  • Sep 2018
                                  • 1
                                  • Romania
                                  Hi, I tried it, unfortunately the laptop does not start with this bios.
                                  • shkura192
                                    • Jun 2018
                                    • 1
                                    • Ukraine
                                    Thanks.
                                    Hello . Who has a unlock bios from the panasonic cf c1 mk1?
                                    • liu00901
                                      • Nov 2018
                                      • 8
                                      • China
                                      panasonic CF-C1 Workig 's BIOS File
                                      • liu00901
                                        • Nov 2018
                                        • 8
                                        • China
                                        Originally posted by liu00901
                                        panasonic CF-C1 Working 's BIOS File
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
