Panasonic CF-C1 BIOS
  • diif
    • Feb 2014
    • 6978
    • England
    I'm looking for a BIOS dump for this Panasonic CF-C1 if anyone has one.
    Thanks.
  • Meck
    • Jan 2015
    • 5
    • Bosnia
    Re: Panasonic CF-C1 BIOS
    i have cf c1 mk1 but i need mk2 did have sameone ?
    • rioreno
      • Feb 2009
      • 540
      • Indonesia
      whats problem with your bios cf-c1-mk2? can you post your old bios?
      • diif
        • Feb 2014
        • 6978
        • England
        It's password locked. I can read it if that will help, I will need to disassemble the laptop first though.
        • rioreno
          • Feb 2009
          • 540
          • Indonesia
          for cf-cf1 mk1 i'm sure it can be remove the bios password,you can get your file from panasonic.. but for cf-c1-mk2 there is no update file...
          this is for your bios diff (cf-c1-mk1)
          but you need to fill dmi by your self..
          better your try..
          goodluck
          eeh, btw your type mk1 or or mk2??
          • diif
            • Feb 2014
            • 6978
            • England
            Thank you. I will dig it out later and let you know.
            • stefanciprian
              • Feb 2017
              • romania
              better your try..
              goodluck
              Thank for this dump!
              • jfpico
                • Dec 2017
                • 10
                • españa
                Hello, my English is very bad.
                I have a cf-c1 mk2. with bios passwords. I already have the dump of this team. can I remove the passwords by modifying the dump file?
                Or look for a file without passwords would be enough. Thank you.
                • jfpico
                  • Dec 2017
                  • 10
                  • españa
                  This is my dump bios with passwords. in case someone knows how to remove it.
                  • rioreno
                    • Feb 2009
                    • 540
                    • Indonesia
                    try this...
                    goodluck and please confirm...
                    • jfpico
                      • Dec 2017
                      • 10
                      • españa
                      try this...
                      Thank you very much. on Tuesday I try it and I assure you that I will post with the result. I am incredibly surprised by your speed.
                      • jfpico
                        • Dec 2017
                        • 10
                        • españa
                        Hello, I've tried it and it does not work. does not turn on the computer.
                        • george_gpu
                          • Dec 2015
                          • 77
                          • greece
                          good day
                          i need help , i need bios rom for panasonic cf ax3
                          • jfpico
                            • Dec 2017
                            • 10
                            • españa
                            In the end I bought a second-hand motherboard and extracted the bios and it works ok. Here I leave the dump of CF_C1 mk2. without passwords.
                            • VFR3000
                              • Mar 2018
                              Hi Anyone know what mk this CF-C1 is?
                              Model Number: CF-C1KT01GGE
                              MANY THANKS
                              • xzm
                                • Feb 2011
                                • 28
                                MANY THANKS
                                This is mk1 type, because if is after CF-C1 "K" or "A", then is this mk1 type.
                                • ceosmihail
                                  • Sep 2018
                                  Hi, I tried it, unfortunately the laptop does not start with this bios.
                                  • shkura192
                                    • Jun 2018
                                    • Ukraine
                                    Thanks.
                                    Hello . Who has a unlock bios from the panasonic cf c1 mk1?
                                    • liu00901
                                      • Nov 2018
                                      • 8
                                      • China
                                      panasonic CF-C1 Workig 's BIOS File
                                      • liu00901
                                        • Nov 2018
                                        • 8
                                        • China
                                        Originally posted by liu00901
                                        panasonic CF-C1 Working 's BIOS File
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          💀 Problem:😅
                                          08-07-2025, 04:54 AM
                                        • sedat88
                                          Panasonic CF-54DY024NG Bios Dump
                                          by sedat88
                                          I'm looking for Panasonic CF-54 bios dump.
                                          Flash memory with bios is damaged and is not possible to recover any information from it.
                                          Model Name - CF-54DY024NG
                                          S/N: 6DTSA61473
                                          Thank You...
                                          09-29-2025, 03:03 AM
