I recently had a board crap out on me and as I took the case off I noticed some bad capacitors. I want to replace them, but its an old board and I can't find the exact capacitors. I'm able to find caps with the same voltage and uf rating, but not the same series number. I know the diameters as well. The caps are rubycon 16V 1800uf mcz, rubycon 6.3V 2700uf mfz, and samxon 6.3V 1500uf gc (m) voa. I can find the rubycon mcz on amazon, but the others I can't find. So I'm thinking to just go into digikey and choose caps with similar voltage, uf, and diameter for all of them. Is that fine?
Also, when soldering, I'm new to this as well, I notice that my iron doesn't melt the solder to liquid, it melts it and then it falls down into a ball. Is my soldering iron not hot enough? Its a radioshack brand, and I'm using the 40W setting (highest it goes). Ive never tinned my iron because as I try to it just makes the solder fall off into a ball, so it doesn't stick to the iron.
