Re: Do I need to use the same exact model and series or can I use any similar capacit
So my multimeter arrived. I'm not sure what you mean by 5vsb and 3vsb. The manual for my motherboard is here. Are there any specific components I should test first? Definitely going to test the caps I changed and anything in its area, and I guess I should test the power header.
I'm checking out some videos on how to use the multimeter right now.
Do I need to use the same exact model and series or can I use any similar capacitor?
yeah I did reconnect it. Ill try again, maybe I had a loose connection. Anyway I ordered a multimeter, so I'll run those tests in a few days. Thanks for all your help so far!Leave a comment:
u'll have to probe whether the 5vsb reaches the board properly and gets converted properly to 3vsb, whether the power switch header on the board gets power among other things. btw, after recapping the board and putting it back into the casing, u did reconnect the power switch header to the board? did u?Leave a comment:
Alright, so they arrived, and I was able to force the PSU on. The fans worked. So I take it the PSU is fine, at least fine enough to power a couple of fans. Any other things I can try to figure out why the board won't get any power? If I buy a multimeter, how can I test components and the board itself more importantly?Leave a comment:
I just bought 100 on amazon for $5, with amazon prime thats free shipping and I'll have it monday. What do to with the other 99 hahaLeave a comment:
i didnt wanna suggest getting those jumper wires online as u'll have to find a site that offers free shipping even for low-cost items. doesnt make sense to pay several bucks shipping for an item that costs less than a dollar.Last edited by ChaosLegionnaire; 04-16-2016, 05:27 PM.Leave a comment:
Great, I'll try and get some by monday, these days its hard to come by electronic stores and they said they didn't have any at radio shack.... I think I'll just purchase them online and report back when I get it done. Or I might strip apart an extra sata cable I have lying around and use that.Leave a comment:
yes, i said green wire on the main atx connector. jumper wire looks something like this.
if u arent an electronics hobbyist and dont have any loose wires lying around that u can pull out and use, then prolly head over to whatever nearest electronics store closest to you and show them the pic of the jumper wire u want and buy some. its less than a dollar for one or a few of 'em.
for safety reasons, do NOT use any bare or exposed wire and have that bare exposed wire touching your skin when shorting the green wire as we dont know the condition of the psu.Last edited by ChaosLegionnaire; 04-16-2016, 01:42 PM.Leave a comment:
OK, so I tried unplugging everything and only leaving in two of the fans connected to the PSU. When I turn the power on the PSU on, I don't get any movement whatsoever, I don't even hear a sound. The PSU fan doesn't jerk at all, not even when everything was plugged in, let alone only the case fans.
I'm not sure which green wire you're talking about, is it the one in the picture i attached? Also don't know what jumper wire is, do I just take any wire I have lying around, stick it in the connector where the green wire is, and then connect that to one of the black wires on the atx connector too? Sorry for making you dumb it down so muchLeave a comment:
the numerical leds in the other led pic are most likely post diagnostic leds. your board has a post card function built in so u dont need a post card. however, they are only meant to work when the motherboard is powered on and starts the bios boot process.
since, it wont even power on. we have to check first if the psu is working. does the psu fan jerk a bit when u push the power button? also, unplug everything connected to the psu except the fans then try to use a piece of jumper wire and short the green wire on the atx connector to any black wire. this forces the psu to turn on without a board. does the psu fan remain spinning and do the case fans remain spinning? this usually just indicates the main rail side of the psu is not dead.Leave a comment:
I don't have another system to test the PSU on, at least not a system I'm willing to mess with. Although I doubt it was the PSU because it should still let the motherbard POST as it was before right?
I do want to show you guys the results of my cap replacements (5 pics attached, sorry its really hard to take a picture of the back of the board so that probably won't be very useful), as well as the LED which lights up on the board (2 pics attached, one for on and one for off) when I give it power. The last picture attached is just to show how there is something on the board, not sure what it is, that looks like it should be lighting up as well but is not. I saw it on some pictures of a POST card, so I assume the fact that this is not lighting up is a big deal.
I'm willing to buy a multimeter, can you recommend one? Hows this?
Also I appreciate your help, this is fun but hard to get somewhere when you have no experience.Leave a comment:
a post card is a pci diagnostic device card and inserts into the pci slot and displays various post checkpoint codes as the board boots up. that way u can figure out what is causing the pc to hang and not boot. however, in your case its not necessary as your board wont even power on!
you could also have multiple faulty components. what psu are u using? im inclined to think it may be a bad psu as the system self reboots abruptly and now it wont even power on. also, bad psus are known to make mobo caps fail and go bad! do u have another system to test the psu in to see if it powers on as well?Leave a comment:
I can get a multimeter, haven't ever used one, but this has been a fun learning experience. Not sure what you mean by a post card?
I know I inserted the caps correctly, at least polarity wise. Regarding it being able to start post,the computer would actually boot all the way into my operating system for about 5 seconds before restarting prior to me recapping it. I took it apart and saw the busted caps, so I figured that was the issue.Leave a comment:
figuring out and troubleshooting why a motherboard wont start post can be technically challenging and complex. u need at least a multimeter. do u have one? if u also have a post card, that will help as well.
u can start by just visually checking if u inserted the caps with the right polarity in the board. also, was the board still able to start post before u recapped the board?Leave a comment:
I didn't completely understand the instructions though, steps 1 and 2 sound the same to me, but I plugged the power supply back in after I switched the jumper cap to pin 2 and 3 and tried turning it on, unplugged the power supply then switched the jumper cap back to original positions and tried turning it on again, but no luck. Should I try removing the battery totally?
Either way though, is there no easy way to test the motherboard by itself? I'm worried that its most likely a loose wire, or just simply the capacitors not being installed properly. Worst case is I did too much damage to parts while working on the board, but like I said there is an LED lighting up when the board is plugged in so thats giving me hope.Last edited by giyad; 04-14-2016, 11:36 AM.Leave a comment:
errr did u remember to remove the cmos battery before u recapped the board? if u didnt, try clearing cmos to see if the board starts up after that.Leave a comment:
So I received the capacitors and replaced them. It wasn't too bad actually, pretty simple to replace. The only issue now is, my computer won't turn on. Most likely I either damaged the board, the parts are not correct, or I didn't actually do a good job with replacing them like I thought I did.
Does anyone know how I can test the board alone? When I plug it into power, an LED (SV STBY is what it says next to it) on the board lights up, so maybe I just have a loose connection, but I'd like to test the board if thats possible.Leave a comment:
That would have been great but Rubycon doesn't have any of the caps I'm replacing in their lists on their website. Its like they were all custom for this board. Anyway, those sheets are good to know about, I've already ordered my replacement parts just waiting on them to arrive. I'll let you guys know how it goes.Leave a comment:
Wow that's really useful, got any more examples?
I found this one:
Generally, most of the large electrolytic capacitor manufacturers (especially the Japanese ones) have a "Standardization" catalog (or similar) of recommended current series to replace discontinued series e.g. Chemi-Con KY will replace Chemi-Con SXE:
- link valid at time of posting.Leave a comment:
This specification for the Acer Chromebook Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron) boardview and Acer Chromebook Spin 713 CP713-3W - (Intel Core i3-1115G4, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen...09-07-2024, 03:10 AM
This specification for the Acer Chromebook Acer Chromebook 514 CB514-1W - (Intel Core i3-1115G4, 8GB, 128GB SSD, 14 inch Full HD Display, Google Chrome OS, Iron) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook 514 CB514-1W - (Intel Core i3-1115G4, 8GB, 128GB SSD, 14 inch Full HD Display, Google Chrome OS, Iron) boardview and Acer Chromebook 514 CB514-1W - (Intel Core i3-1115G4, 8GB, 128GB SSD, 14 inch Full HD Display, Google Chrome OS, Iron) schematic. Our users...09-07-2024, 01:30 AM
This specification for the Acer Swift Iron, Intel Core i7-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Iron, Intel Core i7-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS boardview and Iron, Intel Core i7-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 01:00 AM
This specification for the Acer Chromebook Intel Core i5-1135G7, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Intel Core i5-1135G7, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron boardview and Intel Core i5-1135G7, 8GB, 256GB SSD, 13.5 inch QHD 3:2 Touchscreen Display, Google Chrome OS, Iron schematic. Our users have donated over 1 million documents which are...09-07-2024, 01:00 AM
This specification for the Acer Swift Iron, Intel Core i5-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Iron, Intel Core i5-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS boardview and Iron, Intel Core i5-11300H, 8 GB, 1024GB PCIe NVMe SSD, FHD, IPS schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 01:00 AM
- Loading...
