t con no power
  • cossiejay
    • Nov 2010
    • 83
    t con no power
    advice needed please will the main board be a fault if i have no power to the t con board cheers
  • Diah
    • Feb 2013
    • 6566
    Re: t con no power
    depend on brand and model
    • cossiejay
      • Nov 2010
      • 83
      Re: t con no power
      its a hitachi l32hk04ul
      • Diah
        • Feb 2013
        • 6566
        Re: t con no power
        can you upload photo of the T-CON , and what kind of fault the TV had exactly.
        • cossiejay
          • Nov 2010
          • 83
          Re: t con no power
          will upload pic tomorrow fault is no picture i have everything else sound backlights etc got multi tester on t con board fuse is ok but no voltage or power to the t con
          • Diah
            • Feb 2013
            • 6566
            Re: t con no power
            did you try to disconnect the T-CON from the panel and test voltage?
            did you test voltage at main boards before the LVDS to T-CON?
            • Diah
              • Feb 2013
              • 6566
              Re: t con no power
              okay, i saw the T-CON 6870C-0313B , replace it, its cheap on ebay. less than 10USD
              • cossiejay
                • Nov 2010
                • 83
                Re: t con no power
                is it going to be the t con board when there is no power going to it
                • Diah
                  • Feb 2013
                  • 6566
                  Re: t con no power
                  the answer of this question will be found after you answer my questions on post No #6
