Looking at a TV for a friend. Power supply (BN44-00214A) appears to be ok. I can pull the PS_ON pin High and seem to be getting the proper output voltages. My problem appears to be with the main board, BN97-01995D. As soon as I plug the main board into the power supply, the power supply turns on. The main board is supplying ~3.5v to the PS_ON pin. After a few seconds it drops out, power supply turns off, then back on. It continues this cycle until the AC input is removed or the main board is unplugged. I can't find a schematic for the main board ANYWHERE. Anyone have experience troubleshooting one of these mainboards?
Samsung LN32A450C1DXZA won't power on
Re: Samsung LN32A450C1DXZA won't power on
Actually just came across this thread
Looks like inverter is a common fault. Check any fuses on it.
Pretty sure it's a main board issue. I can heat up the shielded portion of the main board and everything is normal. It doesn't send the PS_on signal until I push the power button. At which point the tv turns on fine. I am going to try and remove the shield and see what I can figure out. Will report back.
Here's what's under the shield. Any thoughts or suggestions? There is a tantalum cap on the bottom of the board similar to the c102. Looking at the data sheet it is a 100uF 6.3v looks like it is on the 2.5v line. Was planning on changing that and going from there.
Thanks for the follow-up on the repair, $20 is a great deal.Never stop learning
