Samsung LN32A450C1DXZA won't power on
  • TheWraith
    • Mar 2012
    • 10
    • US
    Looking at a TV for a friend. Power supply (BN44-00214A) appears to be ok. I can pull the PS_ON pin High and seem to be getting the proper output voltages. My problem appears to be with the main board, BN97-01995D. As soon as I plug the main board into the power supply, the power supply turns on. The main board is supplying ~3.5v to the PS_ON pin. After a few seconds it drops out, power supply turns off, then back on. It continues this cycle until the AC input is removed or the main board is unplugged. I can't find a schematic for the main board ANYWHERE. Anyone have experience troubleshooting one of these mainboards?
  • martyparish
    • Dec 2012
    • 313
    Re: Samsung LN32A450C1DXZA won't power on
    Maybe consider the t-con or inverter boards. The main board could be sensing error from one of those boards and shutting it down.
    Pictures would probably help get more responses.
    • martyparish
      • Dec 2012
      • 313
      Actually just came across this thread
      Looks like inverter is a common fault. Check any fuses on it.
      • cliff_hootarski
        • Jul 2006
        • 411
        Please supply a good focused picture of the back of the main board.
        Look for C102, usually needs replacement.
        • CapLeaker
          Leaking Member
          • 8190
          google "budm c102".
          • TheWraith
            • Mar 2012
            • 10
            • US
            This board doesn't appear to have the c102 cap described in the other threads.
            The reason I suspect the main board is due to the fact that it is sending the POWER ON signal as soon as it's plugged in, WITHOUT pressing the power switch.
            • TheWraith
              • Mar 2012
              • 10
              • US
              Backside
              • TheWraith
                • Mar 2012
                • 10
                • US
                To the top
                • martyparish
                  • Dec 2012
                  • 313
                  POWER ON after plug in is normal for many tvs. You may be correct abt the main board but it sure won't hurt to test any other known faults before digging into the main. Good luck with it.
                  • CapLeaker
                    Leaking Member
                    • 8190
                    I guess we need to know what the PSon / BLon pins do when the TV goes nuts.
                    • TheWraith
                      • Mar 2012
                      • 10
                      • US
                      Pretty sure it's a main board issue. I can heat up the shielded portion of the main board and everything is normal. It doesn't send the PS_on signal until I push the power button. At which point the tv turns on fine. I am going to try and remove the shield and see what I can figure out. Will report back.
                      • CapLeaker
                        Leaking Member
                        • 8190
                        Look inside that shielded portion and check if you see any capacitors. If you do, change them all with quality caps and report back.
                        • TheWraith
                          • Mar 2012
                          • 10
                          • US
                          Here's what's under the shield. Any thoughts or suggestions? There is a tantalum cap on the bottom of the board similar to the c102. Looking at the data sheet it is a 100uF 6.3v looks like it is on the 2.5v line. Was planning on changing that and going from there.
                          • TheWraith
                            • Mar 2012
                            • 10
                            • US
                            Got a replacement mainboard for $20, and she's alive again. Thanks for all the input and suggestions.
                              Thanks for the follow-up on the repair, $20 is a great deal.
                              • Dani_2024
                                by Dani_2024
                                10-28-2024, 05:06 PM
                              • JDC
                                (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                by JDC
                                ONN 100012588
                                Issue: No Power, Then Rebooting After Main Board Change
                                Short answer: replace main board and power board
                                Technical answer: replace main board and Q306 & Q307 on power board.
                                Long answer:
                                TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                07-15-2022, 07:39 AM
                              • Asraf Atb
                                by Asraf Atb
                                01-27-2025, 05:02 PM
                              • C152Heavy
                                by C152Heavy
                                Summary for TL-DR readers:
                                • VCC pin (18) of PFC...
                                01-11-2023, 02:53 PM
