Panasonic SA-AK330 repair, error F61 on display
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    This compact HiFi system shows error "F61" on display as soon as it's turned on, and then it shuts off at once. It's a quad amp with High-Low separated outputs, with a very expensive and hard to find RSN315H42C AMP IC.
    From Service Manual one can read that F61 error is related to power amp (DC detected in output...), but from own experience with Panasonic audio equipment I know that it can be a problem with cooling fan too. I've found similar issues with SA-AK250, SE-CH770, SE-CA1080... and it's never just a single cause, as SM insists it's only "Power Amp output abnormal". Easy to check: just disconnect cooling fan, raise volume up to -14dB and F61 triggers immediately. It's a 2 wire 12VDC fan, but the driver circuit is able to detect its presence and if its turning or not. Common in Panasonic.
    The odd thing is that after partial disassembling, F61 error disappears and audio output is normal. Cooling fan seems fine. After some tests i decide to reassembly it and return to the customer, but then problem shows up again! Then I discover that it only fails when CD loader/changer is connected. F61 related to CD? WTF?
    Checking this part with detail I detect that CD spindle/sled/focus/tracking driver IC7003 (AN8739SB) has been getting hot for years, as the PCB is "browning" below it. Most importantly, CD +7.5V is barely 3V. C7614 (CapXon 100uF/6,3V, close to IC7003) shows abnormaly high ESR and decoloration due to heating, but it's not directly related to +7,5V. C7334 (Panasonic 220uF/10V) is related to +7,5V but it doesn't look bad. I replace both anyway, with no change in voltage. I isolate +7,5V from IC7003 and voltage doesn't improve. Down to the power supply I get to D5805 and D5807 (1N4003S). D5805 has 9V OK, but D5807 has 9V on Anode and just 3V on Catode. Replace it and +7,5V is OK, CD works and no F61 anymore.
    I'll test if for some days before returning it to customer, because I'm afraid that it won't last. Why CD motors driver gets so hot? Panasonic/Matsushita CD/DVD spindle / sled motors aren't the best ones and I've had to replace quite a few.
    BTW, I found (at yoreparo.com) an interesting trick to replace a faulty RSN315H42C. As this IC is really expensive and scarce, there's a chance to replace it with a less hard to find RSN314H41A. First one has 18 pins, while second has 14 pins, but same pitch. As these Panasonic ICs are undocumented, one can only rely on schematics from equipment that uses them. It turns out that pins 1-2 and 17-18 from RSN315H42C are ±VCC clones, while pins 3-16 are identical to RSN314H41A pins 1-14. So the trick is to insert the latter in 3-16 holes. As this IC is smaller than the original, perhaps you'll have to drill new mounting holes for screwing it to the heatsink. Surprisingly enough, in the SA-AK330 case, these holes are already made from factory!
  • turnkit
    • Sep 2016
    • 2
    Re: Panasonic SA-AK330 repair, error F61 on display
    Good info! Thanks for the insight on the IC replacement. Very clever!
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
      11-20-2024, 08:52 PM
    • kodox
      ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
      by kodox
      since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
      the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
      what i've done:
      - flashing...
      12-29-2024, 02:49 AM
    • quickname
      Cyberpower 1500AVR UPS repair
      by quickname
      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
      Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
      I decided to verify that the batteries were...
      11-12-2023, 09:57 AM
    • corrize
      Where to find a very small fpc connector 0.3mm between 2 pins ?
      by corrize
      Hello, I search this connector (oxydated).
      It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
      I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
      I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
      Do you know how to find this connector please ? What is the exact name for find it ?
      08-06-2024, 05:25 PM
    • pkslowk
      Debug Card Error Code and Solution
      by pkslowk
      Sr. Motherboard Debug Error Code Solution
      1 Intel 845 E9 Bios Related Problem
      2 Intel 845 D4 CPU Socket Related problem
      3 Intel 845 37 Bios Related Problem
      4 Intel 845 7C Bios Related Problem
      5 Intel 945GCPE 34 Bios Related Problem
      6 Gigabyte 845 2 Ram Related Problem
      7 IBM Server A6 A7 Ram Mismatch Problem
      8 Asus 845 29 CPU Related Problem
      9 Lenovo I946 97 C-Mos Jumper related
      10 Gigabyte 845 A0 CPU Related Problem
      11 Asrock G31M-VS D7 Bios Related Problem
      12 Compaq 845 BD-70G B0 CPU Socket Related problem...
      01-28-2021, 12:51 PM
