Dead High Power HPC-560-A12S
  • imaddicted2u
    • Dec 2015
    • 101
    I've had this broken power supply sitting around for a few years and would like to take a crack at fixing it. It is a High Power HPC-560-A12S. Sirtech is printed on the board as well as NO610 Rev.03. It seems it was marketed under the same model number by Sirtec. Does anyone know if there might be a schematic floating around for it. I contacted High Power and they won't give me one. Any help or pointers would be handy and appreciated.
    It used to display the wattage in use.
    So far I know the fuse is good and the full wave bridge rectifier on the board is getting 120 vac in and putting out 166 vdc out.
    Here are some other pics of the board:
    This is the manufacturer product page
    http://www.highpowersupply.com/hpc560A12s.html
    Last edited by imaddicted2u; 12-21-2015, 02:52 PM. Reason: forgot to subscribe to thread.
    • 31281
    Re: Dead High Power HPC-560-A12S
    get it open and post some foto's
    • fzabkar
      • Mar 2009
      • 772
      Measure the voltage at the 400V capacitor. This should tell us if the APFC circuit is working.
      • imaddicted2u
        • Dec 2015
        • 101
        Thanks for reply.
        A few pics are posted in the original post.
        I don't measure any voltages from any of the power supply connectors.
        On the back of the main board, I measure 120vac in to the bridge rectifier and 166 vdc out of it. So at least I know the board is getting power. The 166 vdc traces also go to a CM6800G on the daughter board. There doesn't seem to be any voltage on pin 13 (VCC) of that chip. It's hard to see under the heat sinks to trace things out.
        • fzabkar
          • Mar 2009
          • 772
          There should be a high value resistor or two feeding the Vcc pin of the CM6800G. The other end of the resistor should go to the positive pin of the bridge rectifier. These "startup resistors" often go open circuit. The 400V capacitor should have 166VDC at present, but will have around 380V when the APFC circuit is working.
          See page 15 of the datasheet for an application circuit:
            • 31281
            i dont see any pictures.
            you didnt attache them correctly.
            • imaddicted2u
              • Dec 2015
              • 101
              Thanks. You are right, 166VDC at the cap right now. I'll try to track down the resistor next.
              • imaddicted2u
                • Dec 2015
                • 101
                Don't know, I can see them all in the forum, even when logged out.
                I used insert image not attach files, is there a preference on this site?
                I just attached them. Try now.
                  • 31281
                  now i see them
                  • fzabkar
                    • Mar 2009
                    • 772
                    I don't see the original inline images in Opera, but they're OK in OffByOne and Firefox.
                    http://i65.tinypic.com/2vhymax.jpg
                    http://i64.tinypic.com/20hlwe8.jpg
                    http://i68.tinypic.com/2mc64uc.jpg
                    http://i66.tinypic.com/300sb4i.jpg
                    http://i68.tinypic.com/iz2stg.jpg
                      • 31281
                      you need to get ALL the dust out for a clear inspection, because there has been a high-voltage flashover on the bottom of the board.
                      also, the big vertical board needs completely resoldering where it joins the main board.
                      • imaddicted2u
                        • Dec 2015
                        • 101
                        Haven't found any open resistors. I attached a pic of the back of the daughter board and added the traces as they feed through to the other side of the board. I'll try to track it out some more tomorrow.
                        • imaddicted2u
                          • Dec 2015
                          • 101
                          I'll give it a good cleaning and resoldering tomorrow.
                          • imaddicted2u
                            • Dec 2015
                            • 101
                            Cleaned up, re-soldered both sides of daughter board to main board connector.
                            Plugged it in afterwards, still no power up.
                            • fzabkar
                              • Mar 2009
                              • 772
                              You need to follow the VCC pin (13) back to its source supply. Either VCC is shorted to GND (pin 10), or one of the feed resistors is open.
                              • imaddicted2u
                                • Dec 2015
                                • 101
                                Not convinced this is it but I noticed while measuring R33, it was intermittent depending on where and how hard I pressed. Tried re-soldering it but made no difference. There's nowhere local to buy components so I have to order one to try so I'll report back when I get it.
                                Thanks again.
                                • fzabkar
                                  • Mar 2009
                                  • 772
                                  ISTM that R33, R34, and R35 are the feedback resistors that sense the output voltage. That's the function of the VFB pin (15). You need to locate the power feed to pin 13.
                                  • robert
                                    • Jan 2008
                                    • 69
                                    Is there any voltage on +5Vsb?
                                    The standby converter also supplies power to the PWM controller, so if it doesnt work, nothing will.
                                    There will be no "start up" resistor around the CM6800 in a typical PC power supply. There are 2 dividers for sensing line and bulk voltage but these are not used for supplying its Vcc, as it is supplied by a winding on the standby supply.
                                    • imaddicted2u
                                      • Dec 2015
                                      • 101
                                      Nope, there is no +5Vsb. If it provides the VCC for the CM6800, that explains why it doesn't track its VCC back to the 120 VDC at the bridge rectifier.
                                      Thanks for the info, I'll try to figure out why there is nothing on the +5Vsb line and go from there.
                                        • 31281
                                        see if it uses a startup capacitor
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
