Asrock A770DE+ bad caps
  • csh
    • Mar 2015
    • 38
    • Croatia
    I have a board from the subject and it is running stable, almost 24/7 for a couple of years now. On recent HDD upgrade i noticed a bulged cap near the NB heatsink, marked with the red rectangle on the picture below (picture taken from Asrock website):
    Closeup of the bad cap:
    Since that cap is bad, I'd like to replace it to avoid any later unplanned downtime
    It is a Samxon GK series 1000uF, 6.3V. The other 24 same model caps look ok.
    There are also some of the dreaded United Chemicon KZG series:
    Now, a couple of questions:
    1. would it be wise to recap also the neighbors of the bad cap? There are 2 more in the row + small Teapo SS series 100uF 16V.
    2. What about KZGs, to recap or not to recap?
    There are 4 near the VRMs as seen on the picture. No sign of leakage or bulging but they are a little wobbly, possible bulging on the botom?
    Thanks, any help is appreciated
    • 31248
    Re: Asrock A770DE+ bad caps
    right now, i would just replace that row of 3 - they are going to get hot from the fets/regulators below them and the heatsink above..
    question is what to use - electrolytics or poly's.
    what diameter are they - 8mm?
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Yea I agree with that^^
      But maybe take another close look on those KZG's, as you say they look to be quite far from the PCB, maybe you can look in from the side to see how the bungs look underneath?
      Of course with any repair like this you have to weigh cost vs benefit, if system uptime is important to you and you want many more years I'd replace all Samxon and UCC caps on it...
        • 31248
        keep an eye out for dead or damaged server motherboards - you can rob all the poly's off them
        • csh
          • Mar 2015
          • 38
          • Croatia
          OK, I'll replace the 3 Samxon's in a row. They are 8mm.
          As for the KZG's, I'll leave them for now. On the first sign of instability they are out.
          Changing all the caps on MBO is not economically viable option, it would be cheaper to buy new MBO. It's an old platform anyway so changing MBO would require new CPU, RAM, etc.
          I'm not in the server business, the firm I work for has subcontractors for that, could ask guys from hardware dept, they probably have some leftovers but it would be old machines. Polymer caps are usually rated with longer lifespans. Shouldn't we be careful with old caps, i mean they sure have some working hours?
          I guess I'll go with electrolytics, this PC would probably be history by the time they fail again
          Would have to see what is available online in the EU.
          Any recommendations what specific brand/series to look for?
            • 31248
            i dont think anyone has seen a poly go out of spec because of age yet.
            they dont have liquid in them to dry up.
            • Stefan Payne
              • 1267
              I'd probably replace those KZGs also, as well as all caps in that circuit. So probably that row of 4.
              Depending on availability it can make sense to use polymers instead because you may get them cheaper...
              Especially since Ultra Low Impedance Aluminium caps are pretty rare these days...
              Here in Germany you really have to look for something equal to NCCs KZG series...
              And Polymers are much harder to find, if you don't want a through hole version...
              According to the datasheet, the Pana FM are pretty close to the KZGs...
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                These should work well as replacements for the GK & KZG's I think:
                https://www.badcaps.net/store/produc...roducts_id=131
                https://www.badcaps.net/store/produc...roducts_id=139
                • csh
                  • Mar 2015
                  • 38
                  • Croatia
                  Thanks, these look like a good match.
                  • csh
                    • Mar 2015
                    • 38
                    • Croatia
                    Update:
                    Had a couple of longer power outages, UPS did shut down the PC as expected but it wouldn't come back up so easily
                    The fans and HDDs would spin but no video output. Shutting it off via the power button and powering back on did the trick - after 2-3 times it would post.
                    Had some Panasonic FRs 8x20 (1000uF,16V) at hand so used them. A bit higher (20mm vs 12) but the MBO is stable now, no problems.
                    Of those three replaced Samxon GKs, the bulged one is dead, other two measure 930 and 880 uF, ESR 0.18 and 0.23 respectively. Don't know how precise my chinese T4 is but the new cap measures 995uF/0.05 so i guess it is close enough.
                    I would probably have noticed that power-on problem before, but once up the PC ran 100% stable, checked with prime a couple of times.
                    Pic of the new caps attached.
                      Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                      by momaka
                      I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                      For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                      https://www.badcaps.net/filedata/fetch?id=3591771
                      https://www.badcaps.net/filedata/fetch?id=3591772
                      It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                      https://www.badcaps.net/filedata/fetch?id=359177...
                      03-12-2025, 03:42 PM
                    • eryjus
                      Heathkit IO-4205 Power Supply Caps
                      by eryjus
                      First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                      I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                      I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                      05-10-2023, 11:21 AM
                      by momaka
                      03-15-2023, 10:17 PM
                    • Paxman_Swede
                      Identifying caps on an old Zoom 9000
                      by Paxman_Swede
                      Hello!
                      I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                      The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                      I have studied the board and...
                      01-14-2025, 09:51 AM
                    • fl0w
                      GeForce 6800GT recap, need help identifying caps and finding replacements
                      by fl0w
                      I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
                      But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
                      I need to replace:
                      • 2x 2.5V 1500µF => I plan to use this
                      • 2x 16V 330µF=> I plan to use this
                      • 1x 6.3V 680µF=> I plan to use this
                      Am I correct with the cap choices?
                      Thanks for...
                      10-02-2024, 11:28 AM
