samsung un60eh6000fxzc no pic
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8215
    Got this Samsung un60eh6000fxzc 60" LED TV in for repair. It has STBY voltage. When I turn it on, I hear the little Samsung sound, the backlights come on but no OSD or anything else on the screen, just black.
    Story goes there was some lightning or brownout. Anyway, the PSU works fine. So I am down over the mainboard BN97- 06546A on the Samsung IC as it is getting hot. The same IC also does the LVDS. Haven't had the chance to run my oscilloscope on the LVDS yet to check if there is any signal coming out or not. The T-Con board is tucked away underneath more plastic. I can't access it through the service panel on the back. Bummer.
    This is the mainboard (tnx to Shopjimmy).
    Re: samsung un60eh6000fxzc no pic
    When lighting hit, it usually damages the HDMI port that is hooked up to the cable or Sat box.
      When you say the IC does the LVDS, do you mean on the one on the T-con? If so I would worry that the panel drivers have been damaged. Unfortunately I don't think there will be an easy way to test. Must have been a really high energy strike to make it through two chains of ICs.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8215
        I have no idea what was hooked up to what port. Could be the RF port or the HDMI port, he didn't know. However, seeing what things look like, it was the HDMI port.
        If you zoom into that picture and look at the big Samsung IC. The HDMI ports go into there and the video comes out of there on the other side and going to the T-Con.
        I am pretty sure that IC is toasted, as it gets pretty warm, that I almost burnt my skin. I also see sweet diddly squat on my oscilloscope hooked up to the LVDS while flicking the menu on and off.
        All I could test of now on the T-Con board was the fuse and it is good. For the rest I need to disassemble the frame to get the T-Con board out and that requires my living room table. So I guess for now I need at least a main board to start with. Grr.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8215
          O.k. got another main board. Got signal coming out of it as I can see it on the scope, but the screen is still black. Backlights come on and I hear the Samsung melody.I guess I have to rip out the T-Con board now.
          Edit:
          unplugged each side seperatly while the other plugged in and screen stays still black.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8215
            Got in a replacement T-Con (thanks to Shopjimmy) TV works fine as kind!
              09-07-2024, 05:50 AM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              08-24-2025, 03:47 AM
            • NolesFan
              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
              by NolesFan
              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
              10-24-2024, 06:36 PM
            • bohaboha
              ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
              by bohaboha
              Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
              04-19-2025, 01:47 PM
              09-06-2024, 11:40 PM
