Kdl-55hx800 4 blink, no picure or sound
  • Tom.molyn
    • Mar 2015
    • 16
    My pal gave me this tv for 40$(Steal!)
    • The tv would power cycle initially.(no picture or sound)
      I was able to get 3.3v on the standby voltage at all times.
      The on power and high voltage would be on for the first 2 seconds inbetween "clicks"
      I replaced the BAL board and the same issue happened.
      I was able to keep the power from cycling when the T-con board was disconnected from the Inverter. (This allowes me to update the firmware and get picture and sound but no backlight)
      All the capacitors look like there in perfect condition.
    I haven't tested the old BAL board without the inverter cable.
    I'm reaching out for input on this, I am debating purchasing a new Inverter board at the moment but i am unsure how to rule out the T-con.
    Thank you for your support All Great Ones.
    -Thomas
    Note:will upload service manual, and pictures when i can.
  • Tom.molyn
    • Mar 2015
    • 16
    Re: Kdl-55hx800 4 blink, no picure or sound
    Here's a photo, and below is the service manual.
    https://docs.google.com/file/d/0B8oy...p=docslist_api
      So you have 4-blink code not 5-blink. See:
      https://www.youtube.com/watch?v=oE6K4xBVweA
      Same idea.
      You should also check the DCV on the SMD fuse on the T-CON board.
      • Tom.molyn
        • Mar 2015
        • 16
        I think i located 4 smd Fuses marked R in green on the inverter, i will test them now.
        Can anyone see any through the potato picture I uploaded?
        Edit: all 4 are fine in circuit on the inverter.
        Tested some pads and discovered that when it starts it gets a high voltage of about 24v by the power supply inputs, it then slowly drops to about 15v where the power relay clicks off. It then continuously re-cycles.
        This is the same near the ribbon cable test pads, about 12v is the high and the voltage drops.
        Sound like a bad cap?
        Also i get no voltage from the pads when the cable from the inverter to the t-con board is disconnected.(i think this is due to its control over the variable brightness)
          There is the fifth one with 'H' (1A 63V) on top.
          So this is LED backlights TV which does not have Balancer for the CCFL, it looks like the BAL board is the main board it is referring to.
          It has LED driver board which probably controlled by the T-CON board for Dynamic contrast function.
          • Tom.molyn
            • Mar 2015
            • 16
            You are right there is a 5th, I just tested it and it shows good in circuit.
            I'm about to order another board, any suggestions? There is a restocking fee at shopjimmy.com that I wouldn't like to pay twice.
              So you did replace the BAL (Main board)?
              It may be good idea to ask SHOPJIMMY as what they think the problem may be.
              • Tom.molyn
                • Mar 2015
                • 16
                I have and I've gotten the tv on without the inverter board plugged in.(no blinks)
                Tried both boards this way, both work the same.
                  Hmm I wonder if the error code is correct then, it is pointing to the LED driver board. I am not 100% sure as to what is going on here.
                  • Tom.molyn
                    • Mar 2015
                    • 16
                    The manual also points toward the Panel(balancer), I cannot tell if its refering to the T-Con or the Inverter(Driver)
                    the tv says its an LCD but it could be powered by LED bulbs or CCFL. I do know that it is edge-lit(variable) which makes me think LED's.
                    • Tom.molyn
                      • Mar 2015
                      • 16
                      Which fuse are you referring to?
                        There should be very small SMD fuse on the T-CON board (the board connected to the LCD panel), but at this point it does not look to be related to the T-CON because you do not get the blinking error code when the LED driver board is disconnected.
                        • Tom.molyn
                          • Mar 2015
                          • 16
                          Yes, however the driver board is plugged into the T-Con board,
                          but on the other hand i still get full(picture and sound) functionality without the Driver plugged in.
                          I took a picture of the t-con board
                          https://www.badcaps.net/forum/attach...9&d=1426885347
                          I do see what looks to be a Fuse near CON10, which is by the power supply port.
                          this is probably irrelevant but i have a Power Saving switch on the side of the tv, when switched off i get no response even with the inverter disconnected but i do get Standby and a Green LED on the front.
                          Also when the LVDS cable is disconnected i get code 5(T-Con) which is to be expected.
                          I've also considered manually powering the LED's in order to test them, I'm unsure of the Voltage/Amperage, I also have no idea how i would do this.
                            The reason there is connection between the LED driver board and the T-CON is that it uses T-OCN to control the brightness of the LED depending on the scene of the video to give you that fake high Dynamic contrast ratio spec.
                            http://www.cnet.com/news/contrast-ra...r-lies-to-you/
                            • Tom.molyn
                              • Mar 2015
                              • 16
                              yes lol on the spec sheet it shows infinite contrast because it can turn them all the way off
                              6. Dynamic contrast ratio compares the luminance of a 100 IRE (white)
                              signal with that of a 0 IRE (black) signal. When the TV receives a 0 IRE
                              signal the backlight is turned off and the luminance measurement is
                              0.00 cd/m . The resulting dynamic contrast ratio is infinite
                              See:
                              So than i feel like I'll test a new Driver board.
                              I wasn't able to find a REV:03 model so i hope the REV:02 works :/
                              http://www.ebay.com/itm/Sony-KDL-55H...tem3f44053ddc#
                              • Tom.molyn
                                • Mar 2015
                                • 16
                                Update!
                                New inverter is in, the backlight now powers up!
                                That is for about a minute.
                                After about a minute it powers off with code 6.
                                Swapped out the BAL board to the new one I'm about to return, resulted with the same issue. The service manual points to the G board, i can only assume the power supply(g4e).
                                Another thing to note is that in the upper left corner theres a dark area like the LED isn't lighting up.
                                The BAL board doesn't have Panel_Fail as the service manual requests.
                                Code:
                                http://www.justanswer.com/tv-repair/7rpqt-hi-sony-kdl46hx803-when-turning-on-quickly.html#re.v/135/
                                Pin 3 of CN2561 is giving 3.34v when off and when it turns on i get the same but it will ocasionaly fluctuate lower around 1.8v.
                                When the Power Supply clicks off i get a reading around .84v
                                Last edited by Tom.molyn; 03-25-2015, 06:39 PM. Reason: Added additional information
                                  I really do not know at this point since the service manual does not seem to match to what you have, so the JL2565 it is referring to in page 29 for 6-blink error code is not there?
                                  • Tom.molyn
                                    • Mar 2015
                                    • 16
                                    It's not I found another post which point it to a different pin.
                                    No matter though!
                                    I discovered that the lights weren't leading up because the ribbon cables weren't flat against the board? I don't know why but all I had to do was press and down with a piece of tape.
                                    It's been going strong for probably about an hour now without any more codes.
                                    Thank you so much for the assistance ^.^
                                    I owe you one budm, is there anyway I can show my appreciation?
                                    I'd be more than willing to tip you, how about a paypal account?
                                    • milkman6453
                                      HVAC
                                      • Mar 2015
                                      • 39
                                      • usa
                                      The dark spot went away as well?
                                      • Tom.molyn
                                        • Mar 2015
                                        • 16
                                        Yes, the ribbon cables must not have been making good contact, or weren't grounded?
                                        To be honest i have no idea why i needed to tape them down, they were in nice and tight with all the plastic fasteners in place.
                                        I have seen ribbon cables that needed to be grounded underneath but these don't have a pad on the underside.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
