Need bios HP G42-458TX
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Hi, does anyone have the bios hp G42-458tx.
    Code: DAAX1IMB6A0 REV A
    Ci5 480m, vga ati radeon
    I accept the notebook can be turned on, but only a black screen. I've checked the voltage at the coils, all the good measured. I touch on HM55 cold, as not to react. cpu and ati touched feels quite warm
    I've done several things, among others:
    replace the RAM is still good, does not solve the problem.
    try to flash the bios main, with bios downloaded from a forum then HM55 gets warm. does not solve the problem
    so I conclude this might seem a mismatch bios or corrupt, and hopefully not the chipset or vga
    I attach the backup bios and bios downloads
  • khaahk
    • Dec 2013
    • 830
    • Estonia
    Re: Need bios HP G42-458TX
    from hp site
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      here is another dump, same motherboard
      main bios 4mb, ec 1mb
      need to flash both
      Im Back... sort of...
      • meritosari
        • Oct 2010
        • 774
        • Indonesia
        need to flash both
        Originally posted by khaahk
        from hp site
        thanks for all your response
        before reading your response, I have several times tried to put the bios of which I found on the web. and did not change anything. in desperation I returned the original bios to be returned to the user, I try to turn it on once again ... it can appear on the screen.
        so the case has been resolved, although the record cpu and vga experiencing excessive heat, as weakness HP in general we know.
        little notes that I made,
        - Bios backup still good, for database badcaps
        - HP laptop does not directly display the boot
        screen, before pressing the power button, we have to press F9 or F10 to force the HP boot via an external monitor.
        - We also need to install the hard disk even if bad sectors, or which can be bootable usb
        thank you for your attention
        I love this forum
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • cr4zychriss
          [Problem/ Request] Bricked TongFang GK7MRFR BIOS
          by cr4zychriss
          I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
          I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
          • Barebone / Chassis: TongFang GK7MRFR
          • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
        • istvanszasz99
          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
          by istvanszasz99
          Product Name: Razer Blade 15 (2022)
          Product ID: RZ09-0421
          Motherboard: CH580
          BIOS Versions I work with: 2.02 & 2.06
          Bios File Size: 32,768 KB
          Dear Forum Readers!
          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
          !!! MY RAZER BLADE...
          11-24-2025, 05:52 PM
