LA-7912p Power proble, need power sequence.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Hello, I have problem with acer E1-571 power problem,
    its +3valw and +5Valw ok but no power. RSM_RST# not found.
    please help. U42 Pin 8 +3vs miss.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Re: LA-7912p Power proble, need power sequence.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      report u36 pin 8 volt and u21 all pins voltage.
      • nazrul145
        • Jan 2014
        • 337
        • BD
        Thanks brother for reply.
        U36 Pin8 0V, U21 Pin5678=3.3V pin123=0V and pin4 also 0v.
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          check voltage on R368 both side. if u have 19v in and 0 volt out, check without power supply for short on that side. if no short, replace that resistor.
          • nazrul145
            • Jan 2014
            • 337
            • BD
            there is no short r368 and replace transistor, but same +3vs not found. PR368 one side 19v and another 0v.
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              have u replaced r368 (resistor not transistor) as i said ?
              it's a 47k 0402 5% resistor.
              • nazrul145
                • Jan 2014
                • 337
                • BD
                i have changed this resistor, but another side is Ov. when i short R368 then q25 transistor burnt. i replace this trasistor also.
                • nazrul145
                  • Jan 2014
                  • 337
                  • BD
                  main problem susp# voltage miss from IO chip.
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    if you remove q25a do u have 19volt both side of r368 ?
                    as atsio said on other topic # means to be low.
                    edit: check also c463 if it is shorted.
                    if not, try remove u21 and measure voltage
                    • khaahk
                      • Dec 2013
                      • 813
                      • Estonia
                      Inspect EC for visual damage.
                      Does the powerbutton take pin 114 of EC to gnd?
                      After that does PBTN_OUT# go low for a while?
                      EC contains its own ROM, so it does not need to read bios at first stage, i think.
                      When changing KB9012/930 it needs to be programmed.
                      • nazrul145
                        • Jan 2014
                        • 337
                        • BD
                        Thanks dellxps15# and Khaahk#. there is no problem q25a and u21. Khaahk yes, powerbutton take pin 114 of EC to gnd. PBTN_OUT# no change. Totally ec have no change when power button change, without ec on/off.
                        I have change ec with new one but i didnt know this ec needs to programmed.
                        anyway i give it to customer by shorting q27b pin1 and pin6.
                        Thanks again.
                        • khaahk
                          • Dec 2013
                          • 813
                          • Estonia
                          Sorry, wrong idea, it has an external EC rom, so at this mb it gets the rom from flash.
                          But as you got it working, then does not matter...
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            c463 shorted both side ?
                            • saularciga
                              • Feb 2014
                              • 55
                              • mexico
                              You have to shorting pins 3 and 5 to u12 can work, if no gate voltage of Q25A, will have no voltage drop in the resistor R368
                              • sachin varghese
                                • May 2017
                                • 4
                                • india
                                I have a strange prblm with Acer Aspire E1 571 (LA-7912p) when i plug adapter Hdd & dvd Drive working with out trigger.whats the issue ?
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • claws77
                                  lenovo flex 5 14itl05 power sequence issue
                                  by claws77
                                  hi guys, my motherboard will not start no matter what
                                  when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                  but rest nothing happens no sign of life.
                                  this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                  with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                  but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                  i have no knowledge of motherboards ....
                                  10-20-2024, 02:48 PM
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
