Why so many Vestel 17PW25-4s failing with shorted diodes - Answer from PSU expert!
    I decided to ask the power supply guy at work!
    He suggested I check the peak reverse voltage on the diodes especially on start up on the 24V rail - most people report that these power supplies blow up when they are turned on. And it's always a shorted diode on the 24V output with associated primary side damage.
    Guess what I discovered. The diodes are rated to 100V, UF5401 type. The peak reverse voltage? 283V. Yes, I kid you not, they are overvolting these parts by nearly 300%. That's one Quality Vestel(TM) Design!
    The transients are repetitive, approximately 20 x ~30ns long over 1.8ms, before it starts ramping up the output voltage.
    Scope traces attached show the extent of the FAIL in this design. Note that this set had 1kV diodes installed after a repair. If the set had 100V diodes installed the voltage would be clamped to not much more than 100V dumping tons of energy into the diodes. In operation the reverse voltage is respected (60-70V peak), but it's the transient that really matters.
    AND, because the diodes are in parallel, there will be one weak link diode which will break down first, dumping all of the transient energy into it.
    The forward voltage bias issue still remains and may also contribute to the failure rate, although after running a 26" set for some time, no one diode seemed to get particularly hot. This was after I installed some metal fins on the diodes to balance the temperature between them though.
    So, the proper fix for these power supplies is a replacement of all the 100V diodes with MIN 400V rated parts and ideally 1kV parts. I used HER308G parts from Taiwan Semi, 1kV rated 3A fast recovery.
    While I am at it, I am not sure why they bothered with the PFC circuit on these power supplies as it does not seem to work properly at all:
    https://www.youtube.com/watch?v=gOOG...ature=youtu.be
    It's more like a passive PFC circuit, but has active components. Very odd. Very Vestel to use parts for odd uses. They've used FAN7710 before - a small ~15W CFL driver - to drive a 200W transformer. It's not thermally overspec'd as it's driving external transistors... but why on earth would they use that given there are many other available parts?
    Blue trace below is line current in arbitrary units.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Why so many Vestel 17PW25-4s failing with shorted diodes - Answer from PSU expert
    Pretty obvious that the PSU was designed by some prat just outta college who hasnt much of a clue how things work--In The Real World.
    In other words, a Virtual Designer--relying on simulations WAY too much, and not Real World physical designs......
    When I design something--I Never use Simulations--I'll build it Then de-bug it.
    (Then again--I Never do digital crap anyway!)
    TELEFIX
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      I hate them, the bane of all my repairs as they normally fail a few months after repair, clearly designed at the lowest possible standard and designed to fail.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Prob design life of a Vestel is only 18 months anyway--and Thats if you are lucky!
        --After all, Cant have 'em last for years on end--They wont sell you another turd in two years if the first turd is still stuck in the waterpipe as it were, will they!
        TELEFIX
        • Dvsr
          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
          by Dvsr
          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
          After replacing the caps I started testing out the speaker. It seemed...
          09-10-2025, 10:20 AM
        • reessi
          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
          by reessi
          Hello:
          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
          I started on the ACER:
          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
          10-29-2024, 11:31 AM
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
        • BalkanBoy
          Dead Razer Blade 14 2022, shorted CPU?
          by BalkanBoy
          today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
          Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
          I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
          Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
          I removed coil and injected 0.7V, it draw around...
          09-27-2024, 12:44 PM
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
