Toshiba A300D-18A Potomac 10A+/AG+ no Power
  • magneh
    • Apr 2014
    • 616
    • Portugal
    Hello!
    I have a Toshiba A300D-18A with no led and no power.
    First check, I noticed that 3.3V were missing @ bios chip.
    Got the schematic for this board, and ended up near U15 where 3.3V go out of Vo2 of this IC. Mesured pin7 and 3.3V where there.
    @ PAD7, I only get 0.28V where 3.3V should present.
    V02 goes to L22, C365 ,C417,R270 and C418.
    Some components arent labeled, so I mesured continuity and found some points that should be these components (marked on photo with voltages).
    Mesured resistance between Pad7 to GND , 25,5 ohm.
    Mesured some of these components in Diode mode and one read open, the other 0.918 , and the one marked in blue 0.03
    How can I go from here without the labels and find out the culprit?
    Or is it that C in blue?
    Thanks for any help!
  • magneh
    • Apr 2014
    • 616
    • Portugal
    Re: Toshiba A300D-18A Potomac 10A+/AG+ no Power
    Hello!
    Well, forget the readings I made on the first post, I was mesuring pin7 of U15 @ pin8
    Well, mesured the right pins of U15 and I dont get 3.3V neither 5V. (see 2nd picture of 1rst post)
    PIN7 (V02) - 0.27V
    PIN24 (VO1) - 0.22V
    PIN16 (VIN) - 19V
    The 19V are there, but the outputs aren't good.
    Should I swap U15 and see from there?
    Or should I check somethig more?
    Thanks in advance!
    • khaahk
      • Dec 2013
      • 815
      • Estonia
      25 ohms seems too small for 3.3v output
      • magneh
        • Apr 2014
        • 616
        • Portugal
        Mesured PAD7 (3.3V ) to GND 900 Ohm.
        Cheers,
        • magneh
          • Apr 2014
          • 616
          • Portugal
          Hello again!
          I'm in a dilemma ... anyone with experience in these 5V and 3.3V getting out of IC U15 ?
          Should I get a new IC or troubleshoot somewhere else?
          Thanks for any inputs!
          • khaahk
            • Dec 2013
            • 815
            • Estonia
            https://cdn.badcaps-static.com/pdfs/...8da1a902a3.pdf
            Chip temp ok?
            Pin 8 - 3.3V ?
            Pin 17 - 5V ?
            Pin 13 - what V ?
            • magneh
              • Apr 2014
              • 616
              • Portugal
              Chip temp ok?
              Pin 8 - 3.3V ?
              Pin 17 - 5V ?
              Pin 13 - what V ?
              Thanks for your help!
              Well here are the readings :
              PIN8 - 3.36V
              PIN17 - 0,01 V (NOK)
              PIN 13 - 1.3V when I put the proble then goes down to 1V in a few secs
              I put my finger on it and 5 secs after I cant support the heat :/
              It's not good I suppose :/
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                pin 13 is enabling signal. if its hot than i think its bad.
                • magneh
                  • Apr 2014
                  • 616
                  • Portugal
                  Ok, so if I wanna change it I must order it from China and wait 3 weeks or should I scrap other boards for it?
                  I Have a few at the office , maybe I can find one in there ...
                  • loser18
                    • Nov 2013
                    • 274
                    Are you getting 25 or 900Ohms from pad7???
                    Also post voltages of PIN1 & PIN6...
                    • magneh
                      • Apr 2014
                      • 616
                      • Portugal
                      Yes, 900 ohm PAD7 to GND.
                      PIN1 - 0.01V
                      PIN6 - 0.01V
                      • loser18
                        • Nov 2013
                        • 274
                        OK...
                        Could You post resistance of all pins @ U15...
                        If it's getting hot, it doesn't necessarily mean that the regulator is faulty (may be some other component around) , but it'll be my bet...
                        BTW it should be interchangeable with RT8205B or UP6182, BUT CHECK DATASHEETS FIRST AS THIS 1 IS CONNECTED DIFFERENTLY THAN USUAL (THERE'S ANOTHER DUAL CHANNEL ENABLE PINS)
                        • whaldsz
                          • Apr 2013
                          • 395
                          • Philippines
                          try removing the solder at PAD7, plug in the adapter and measure if you get 3.3v at L22. we need to know if U15 is the problem.
                          • loser18
                            • Nov 2013
                            • 274
                            I think those +V3A & +V5A voltages are S3 state signals...Doesn't make a sense to have them twice as VREG3 & VREG5...
                            They appears only after pressing PWR button...But I may be wrong...
                            • magneh
                              • Apr 2014
                              • 616
                              • Portugal
                              Bios chip doesnt get 3.3V neither Power button.
                              But I'm not an expert, or I would'nt be here asking for your thoughts
                              And this IC is extremely hot to touch , cant stand 5 secs with my finger on it...
                              Gonna try to find the same regulator and change it if possible.
                              I'll post the results.
                              • magneh
                                • Apr 2014
                                • 616
                                • Portugal
                                OK...
                                Well, verified carefully the resistance of all pins of U15 and coils.
                                Also verified the resistance of PAD7, 8 and 9 to GND and there was an error on the values I gave before.
                                U15
                                PIN1 - 460 Ω PIN2 - 6k Ω PIN3 - open PIN4 - open
                                PIN5 - 6k Ω PIN6 - 51kΩ PIN7 - 3.7kΩ PIN8 - open
                                PIN9 - open PIN10 - 23Ω PIN11 - 24Ω PIN12 - 8.8Ω
                                PIN13 - open PIN14 - open PIN15 - 0.5Ω PIN16 - open
                                PIN17 - 20.7Ω PIN18 - open PIN19 - open PIN20 - 4.8Ω
                                PIN21 - 24.3Ω PIN22 - open PIN23 - open PIN24 - 4.8Ω
                                L22 - 24.8Ω L35 - 4.8Ω L18 - 360Ω L39 - 950Ω
                                PAD7 - 24.8Ω PAD8 - open PAD9 - 4.8Ω
                                My previous reading of PAD7 waswrong maybe to problem with ground probe. Re- verified and it's 24.8 Ω and PAD9 - 4.8Ω .
                                • loser18
                                  • Nov 2013
                                  • 274
                                  Really strange values...
                                  I think the best way is to remove that regulator & check resistance of L22 & L35 to see if the short is gone...& think both rails are shorted cause 25Ω for 3.3V & 5Ω for 5V are too low...
                                  BTW I'm not PRO either & it's hard to do troubleshooting just in theory without mobo in my hands...
                                  • magneh
                                    • Apr 2014
                                    • 616
                                    • Portugal
                                    Ok! Gonna lift U15 and make the readings.
                                    Thanks!
                                    I know that, that's why I wanna thanks to guys like you that help less experienced people!
                                    I'll post results.
                                    Cheers
                                    • loser18
                                      • Nov 2013
                                      • 274
                                      OK...
                                      FORGET ALL ABOUT S3 STATE I'VE SAID...
                                      I found similar mobo (think it's from toshiba L350D) in my "scrapBOX" & managed to get all charger rails working...
                                      I has the same architecture & chips (at least 3.3V & 5V rail) and found that +V3A & +V5A voltages shows up in S5 state...
                                      That means the regulator should drive those voltages immediate after charger plugged in...
                                      NOW I'm 100% sure that you have both rails shorted...
                                      Take that U15 off & post resistance @ L22 & L35 or those PADS...
                                      • magneh
                                        • Apr 2014
                                        • 616
                                        • Portugal
                                        OK...
                                        Well, removed U15 and I see some changes in values ...
                                        L22 - open
                                        L35 - 1.7K
                                        PAD7 - 1.35K
                                        PAD9 - open
                                        Should I suppose short is gone? And U15 is the culprit?
                                        Or should I check any other parts of the circuit?
                                        Thanks!
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          Toshiba Satellite L635-10K Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:33 AM
