PT10G a300 schematic
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    For a long time im searching this schematic but no luck , anyone to send me this , ??
    got here one not doing anything , since im not receiving ENTRIP1 to activate the bloody 5 volts line ad all schematic i have are different , i think i got all a300 schematic less this one :s
    anyone can send me the pt10G schematic _??? thk in advance
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: PT10G a300 schematic
    well fixed that situation about the entrip , fopr what i know there was no EC_PW_ON so replacing KBC solved problem , 5 volts works and turn on , but it turn on 5 second after turn off , then it turn on again and stay on ... i got good voltage on cmos bat , flashed bios allready , this nec was changed some good time ago , meanwhile it came back and notice someone replaced the nec with 6 tantalum caps , but dont look a good job ... would be good havig this schematic to be more sure about certain circuit parts.
    thk in advance
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      well . redone (NEC) but this machine really starting to annoying me .
      turn and turn off 6 sec after , turn on again 2 sec after , then stay on , but no image ..
      all voltages on coils are ok .
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        try those
        good luck
        Im Back... sort of...
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          well tomorrow i will chek but the one i needed was the PT10G and i think you sent me that one . many thank , tomorrow i let you know
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            well i guess this pt10g is a bitch all the time with the 5 volts line , its not the first or the last one ,
            that i got with short on 19 volts line , fix the short , then i can get 3,3 with no problem , but altough 5 volts line not working . chekedd all board and no short found on 5 volts line , no green led as well . usually charger does this (not having 5 volts enable) but all is good with charger (acn pin is with 5 volts as it should be . therefore , cheking main regulator 51125 , only entrip 2 have 1.5 volts , entrip 1 is 0 , and this state beein low makes the 5 volts to be not enable ....what a pain in the ass boards
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              well found the problem , there is no EC_PWR_ON
              so therefore if no power on the gate on Q34 then q35 will make entrip to 0
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                kbc replaced solved the issue
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  wow man, congratz
                  your skill is amazing
                  • jc1
                    • Mar 2016
                    • 1
                    • malta
                    • felix
                      • May 2008
                      • 34
                      I would like to use the same schematics for my board, but i realized that it is A03 (PT10g - 6050a2171501 - rev a03).
                      Does anyone have it ?
                      Thank you in advance
                        Toshiba Satellite A300 A300-14S Laptop Schematic
                        Quanta BL5S Santa Rosa - Rev 1A...
                        11-01-2024, 07:49 AM
                      • TinkerTron
                        Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                        by TinkerTron
                        Hey everyone,
                        I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                        Instead, here's what's been bugging me so far:
                        The schematic...
                        03-06-2025, 02:03 PM
                      • atunguyd
                        Acer x163w Monitor PSU schematic
                        by atunguyd
                        Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                        The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                        03-05-2025, 02:08 PM
                      • Thetechdude
                        MSI Ventus RTX 4080 16G Broadview schematic needed
                        by Thetechdude
                        Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                        I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                        Thanks.
                        07-15-2025, 11:15 AM
                      • ianpoultonknights
                        Zenbook Flip 15 UX562AI schematic
                        by ianpoultonknights
                        Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                        06-26-2025, 02:41 PM
