Hi, I wonder if anyone on here could help me? I have a NAD amplifier that sometimes loses sound to one speaker. I have changed the speaker and still the problem persists so it is the amp. I have cleaned the pot and visually checked the caps but no joy. Does anyone have any experience of this problem in amps?
Faulty NAD c370 amp
Re: Faulty NAD c370 amp
Did you already try cleaning controls and switches? You can also try swithching the Main In in/ Pre-out left and right to see if the problem will still stay in the same channel. It can also be intermittent speaker relay's contacts.Attached FilesNever stop learning
If the headphones cut the speakers when plugged in you could check that part of the switch inside the socket is not sticking open when the headphones are removed. I dont know if the switch IS that type but it is worth checking.
Is the failure on both speakers and headphonesLast edited by selldoor; 08-11-2014, 01:27 PM.Please upload pictures using attachment function when ask for help on the repair
"I switched inputs but still the same problem" I am talking about the Power amp main In put and The Pre-Out jacks on the rear panel. This unit can be used as a preamp or as a power amp unit. What we are trying to find out if the problem is in the power amp section or in the pre amp section. There should be 'U' shape link that are installed in the Main in/pre out jacks. You can also try activating the Tape monitor switches in and out a bunch of time to see if it helps.
For example:
http://img249.*************/img249/4...jumpers5jy.jpgLast edited by budm; 08-11-2014, 02:23 PM.Never stop learning
