Cobolt CB1418TV 14" CRT TV repaired - and a question
  • Agent24
    I see dead caps
    • Oct 2007
    • 5011
    • New Zealand
    Today I decided to look at a little CRT TV a friend gave me as non working, he said it would power on then power off. When I tried, it didn't do anything.
    320V was present at the primary capacitor, and I saw nothing obviously bad in the power supply. Then I checked underneath and spotted two power resistors with broken solder joints (R813, R814). (Also see bodge diode under IC201 )
    I re-soldered them and the rest of the primary side components as some joints looked a little off, and the TV came on just fine - but then I discovered the front panel buttons were not operating properly.
    The design is very simple, they use a resistor ladder with a button at each 'rung' so the IC is just sensing different voltage levels on a single input (Pin 3).
    At first I thought to blame the resistors but that would be unlikely and I thought I better check the simple thing first: Are the buttons working properly? - and guess what - they aren't!
    They are standard right-angle PCB mount tactile switches but the on resistance is all over the place. One of them wouldn't consistently go below 150 Ohms. I guess they were either made of crap or have corroded internally, probably both.
    I also notice they seem to really like axial leaded ceramics! Not sure what the special treatment of C514 on the neck board is for, though.
    But what I really want to know, what is up with the general purpose, 85°C rated capacitors everywhere, even on the SMPS outputs. Is this normal for CRT TVs in general or just the el-cheapo ones like this?
    Edit: Found service guide\schematic etc here: http://monitor.espec.ws/section1/topic121112.html and attached files here in case anyone ever wants them.
    -David VanHorn
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Cobolt CB1418TV 14" CRT TV repaired - and a question
    It's typical for TVs. "Back in the day" they used 85C caps everywhere. But they were high quality ones and also sized properly so they lasted for bloody ages.
    Nowadays some caps placed in high-stress areas are 105C, but they're usually crap brands so they still fail 3-5 years in. I've seen some that even failed during the warranty period. Most of them are still going to be 85C.
    A working TV? How boring!
    • Agent24
      I see dead caps
      • Oct 2007
      • 5011
      • New Zealand
      Figures. But they aren't even low ESR. Is there something about the power supply in a TV that low ESR doesn't matter or are they just cheaping out?
      -David VanHorn
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        1) TVs don't care that much about ripple
        2) If the cap is physically large enough, it's gonna have adequate handling of ripple and sufficiently low ESR even if it's 85C GP. Space is not a concern in a CRT TV.
          Odd, I have a high quality 12 year old CRT (14 inch) using 105°C Rubycon and Nichicon.
          I think it's a matter of costs. The only caps subject to significant ripple are the B+ caps and they're usually very big so can handle high ripple current. The lower voltages for audio and CPU are lower current.
          A modern LCD TV draws most of its power from low voltage rails.
          • DRIFT-O-MATIC
            Sharp LC-40LE431U Manual control buttons not working properly
            by DRIFT-O-MATIC
            I have a Sharp LC-40LE431U TV. The symptoms are when plugged in, the control buttons on the right side panel don't seem to want to work correctly. I get a solid red light. But when I press the Power button, it does not power on immediately. I have to keep pressing ALL the side buttons randomly until finally the solid green light is on. Then when pressing each additional button, they do not always respond correctly, if at all. Pressing the Volume button might bring up the Menu, or vise versa. Even if I can get the Menu screen to come up and scroll through the selections, I still cannot select any...
            02-14-2022, 04:24 AM
          • Dannyx
            Asus G512 no power (BQ24780S problems)
            by Dannyx
            Good day folks. It's been a while since I repaired a laptop, so here's a challenge: a friend of mine asked me to take a look at an Asus G512LI killed by the liquid metal that got smeared all over the board when someone tried to clean it (I'm not blaming it on him - could have been someone before him). I was able to clean it enough to get it going on my own, without any help and thought I was all done, but then I ended up breaking it again
            See, the battery wasn't charging and the laptop wouldn't start on battery either. If you were to start it on AC and THEN unplug the charger,...
            10-16-2023, 11:26 AM
          • tbsmith
            Ninja DCT401 Double oven/air fryer Possible microprocessor issue?
            by tbsmith
            I'm having a random issue with this otherwise nice double oven/air fryer. It sometimes does not respond to the controls. Sometimes only the upper control buttons work, sometimes they all work and sometimes none of them work. The power supply is good as the control board has a steady 5V and 3.3V. The pushbutton switches are all good as tested with multimeter. When the buttons are working, there is about 2.5V to the high side of the pushbutton. I'm assuming pressing a button grounds the input pin to the microprocessor. When the buttons are not working, there is about 0.3 volts on the high side....
            07-12-2025, 11:40 AM
          • LEEDASH
            Aiwa TX-110 Tuner Buttons
            by LEEDASH
            Hello all, Aiwa TX-110 Tuner got out of storage and the buttons was held in by some gloop, What glue would you use to restick these buttons (they are no snapped off)
            Thank you
            05-07-2024, 02:41 PM
          • ohren
            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
            by ohren
            Hello!
            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
            Measured voltages with no load:
            After rectifier diodes
            12V: 6.17 V
            5V: 5.67 V
            Secondary transformer pins AC measurement (really don't know if this says anything)
            12V: 2-2.5 V
            5V: 1.04 V
            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
            03-18-2023, 10:33 AM
