Fix a bad flex tab? From a tv
  • Anum22
    • Jan 2014
    • 12
    Hi, ive been doing a little reseach on how to fix this, but i want to know is it possible? Soldering the thin wires? My kids watered the tv, so then i opened it found a flex tab that had been eaten from corrosion. Please tell me how to hard wire them, its already damed but want to give it a try. I don't know if i should have , but i peeled the tab off.
    Thanks for the help
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Fix a bad flex tab? From a tv
    That sadly may not be repairable. Those are fused on with some kind of epoxy I believe. You could try heating it with an iron but don't think it's going to get very far.
    • dj_ricoh
      • 2073
      • uk
      i`ll subscribe because i`m very interested in this type of repair!
      If there is one
      • Dang
        • Aug 2013
        • 440
        Watch this: http://www.youtube.com/watch?v=yqcqDQFqZHo.
        • Anum22
          • Jan 2014
          • 12
          I watched this, and at the end he said you could try, but i want to know exactly how?
            I'm pretty sure that's not repairable. Too fine for any one to do by hand. Need an expensive dedicated machine to do that.
            • mmartell
              • Oct 2013
              • 3189
              What about that 3M conductive tape that only conducts in one parallel direction ?
              • Anum22
                • Jan 2014
                • 12
                But is there a way that i could try? Its damaged anyways, just want to experiment ? Would the 3m tape work?
                  Worth a shot, I suppose - it's the alignment that's going to kill you, the individual lanes are probably 0.05mm apart. If you can line it up, maybe... Big, big maybe.
                  • Anum22
                    • Jan 2014
                    • 12
                    Have you ever tried somthing like this?
                      No, and I've not heard of anyone doing it either. If you do it successfully:
                      • Anum22
                        • Jan 2014
                        • 12
                        So, i should try with the 3mm tape? Sorry if i ask too many q's , or try to solder it? Also read about a silver pen?
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          It's definitely NOT solderable, you'll break it. Feel free to try other methods.
                          A working TV? How boring!
                          • Anum22
                            • Jan 2014
                            • 12
                            What about conductive copper tape? I just saw it on ebay? Which one should i try?
                            • Anum22
                              • Jan 2014
                              • 12
                              Please tell me , is this what i need to get ? To try to fix it? Is it the same way?
                              www.youtube.com/watch?v=abidHYSlQqs
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                check this out I have a BMW that has a digital display in the instrument cluster and these cars are known for their problem with these having ribbon cable problems here's a good video how to replace the ribbon cable and inside the instrument cluster on the circuit board is very similar in fashion to the top driver boards on LCD so check it out maybe I'll give you some insight.
                                https://www.youtube.com/watch?v=QOiU...e_gdata_player
                                Yes the ipod seems the same idea as well
                                • Dang
                                  • Aug 2013
                                  • 440
                                  I don't exactly know but I would guess that tape may not be suitable for an appication where the temperature fluctuates so much, an Ipod I'm sure is fine but in the back of a Tv, I'm not so sure. The way I see it is heat is used to remove sticky things, whether they be glass digitizers from phones, Ipads or ribbon tabs as he showed in that video, so if it does work, and because of the heat generated, I don't think it will last long if indeed it works at all but as ever, you have to try to see, so good luck, if you do go down this root it will be interesting to see and hear what the results are, Andy.
                                  • Anum22
                                    • Jan 2014
                                    • 12
                                    Thanks i will update , as soon as i get the tape.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Yes but remember in a car with summer heat these things can get extremely hot. The tape adhesion is in the ribbon.
                                      • Dang
                                        • Aug 2013
                                        • 440
                                        The difference I see between the two fixes is the BWM guy is actually using just simple old sticky tape to hold down that type of ribbon cable in place, the Ipod guy is using this special conductive sticky tape that the OP desires to use in this application. The tab bonds do require some level of mechanical strength where as the BMW fix looks to clamp firmly down with the four screws giving the mechanical strength required. I just see this becoming the infamous tab bond issue extremely quickly what with the heat variations that will go on, especially around the tabs, I would have to advise on some pressure over the areas concerned, plenty said here on how that's done.
                                          Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                          09-07-2024, 07:20 AM
                                          09-07-2024, 06:38 AM
