Question about Polarity
  • TKF
    • Oct 2013
    • 31
    • US
    This is my first attempt of recapping a video card from searching and reading these forums I see there is a lot of differences in identifying polarity on capacitors and board markings I have caps ordered I just want to make sure I install them correctly I've included 2 pic please correct me if I'm wrong I'm guessing the hole below the red circle + is the positive and the hole below the blue strip on the cap or the white half moon is the – negative
    Any help would be appreciated Sorry for the questions
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Question about Polarity
    Yes, blue stripe on cap goes to negative (-) side. On almost all boards (almost!), white shaded circle is usually negative (exception is older ASUS and AsRock motherboards).
    • theOracle
      • Nov 2012
      • 163
      what is the brand of the blown cap in the pic?
      the BIG 4
      ~~~ the top tier of low-ESR electrolytic capacitors ~~~
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        ^ U serious??
        Infamous Sacon FZ. Believed to be the crappies of the bad caps. Replace any an all of those bastards. If it has "FZ" written anywhere on it, it has to go. Or expect to be doing a teardown again very soon.
        • theOracle
          • Nov 2012
          • 163
          I must admit I am out of the loop on "solid" caps - gotta get up to speed!
          what are the other bad caps that look "solid" ?
          my work is all on old stuff 2006 and back
          the BIG 4
          • mariushm
            • May 2011
            • 3799
            It's not "solid", it's plain electrolytic in a case that makes it look like it's polymer.
            Loads of nVidia video cards with those Sacon FZ capacitors ... they love to blow up.
            • theOracle
              • Nov 2012
              • 163
              I guess what I was wondering is which other caps that are either solid or have the "solid look" tend to be problematic other than the Sacon FZ ?
              the BIG 4
              • TKF
                • Oct 2013
                • 31
                • US
                Thanks all for your help Sorry for not listing more Info. and #s they are all FZ75 caps on a evga geforce 7600gt card and there are 5-bad 1500uf / 6.3v and 1-bad 470uf / 16v on this board. This is great Info. for rookies like myself hope others readers find it useful as well.
                • theOracle
                  • Nov 2012
                  • 163
                  apparently you need to replace every one marked FZ - whether it appears blown or not!
                  the BIG 4
                  • Dev Goose
                    Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                    by Dev Goose
                    Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                    What Happened
                    The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                    12-13-2024, 03:13 AM
                  • budwich
                    Lithium 12v tool battery charger... no negative connection?
                    by budwich
                    I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
                    03-18-2025, 09:12 AM
                  • 13mh13
                    Aluminum SMD caps vs thru hole caps (reliability)
                    by 13mh13
                    The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
                    https://i.postimg.cc/kGrR6BpZ/image.jpg
                    I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
                    I have not tested/replaced those alum. SMD electro PCB caps.
                    Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
                    All the thru hole electros I removed / replaced on this CDP (and most...
                    04-05-2024, 07:41 PM
                  • brispuss
                    Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                    by brispuss
                    Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                    Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                    I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                    12-28-2022, 02:58 AM
                  • LearningToRepair
                    How to correctly desolder through hole IC?
                    by LearningToRepair
                    Hi!
                    I tried to desolder through I had IC that I wanted to replace but failed. And now I came here to learn what's the correct way for doing this. I tried to use soldering wick but the capillary force kept solder in the hole. With soldering wick I only managed to remove the part of solder that was outside the hole. But the solder that was inside the hole never got out. And of course when I moved on to next pin the solder in previous hole hardened again so no matter how many times I did all the pins there was still solder in holes.
                    Question 1: what would have been correct...
                    07-19-2020, 04:01 PM
