Polaroid 1913-TDXB 3 Seconds To Black
  • SgtRock
    • Feb 2012
    • 175
    Dear BadCappers:
    --This Polaroid 1913-TDXB TV, Monitor with DVD, has the typical 3 seconds to black syndrome. I am pretty sure the problem is on the inverter board, but it does not stay on long enough for me to tell if all the lights are coming on. Attached are two pictures of the inverter board. Could some one please tell me how to get it to switch on, with just the board, and the power supply, so I can determine if the problem is lights, transformer, caps or what have you. The caps are HEC, and probably crap, but they look fine and have not yet been checked and will be replaced as a matter of course if the inverter board is otherwise good. If the inverter and the light are good, I will then check the caps for capacity, open, short and ESR. Otherwise I will probably part the unit out. I am not sure I need a schematic, but it would be nice to have one, just in case, if anyone happens to know where to get one.
    "If it were not for electricity, we'd all be watching TV by candlelight"
    George Gobel 1919 1991
    Best Regards
    Clear Ether
    Re: Polaroid 1913-TDXB 3 Seconds To Black
    Do you see a pin marked BLON, B/L or ON/OFF?
      Since it has 4 lamps, you can have one lamp plugged in one at a time, turn it on and see if you can see the screen light up, do it in a dark room. the inverter transformer also has two high voltage windings, you can check the resistance of the windings.
      • SgtRock
        • Feb 2012
        • 175
        Dear Tom & Budm:
        --Tom: The second picture I posted shows the following labels for the plug:
        +12V +12V
        GND GND
        ADJ BON
        GND PON
        GND GND
        SB SB
        +5V +5V
        --I assume that BON would likely be the pin you are talking about. Do I short that to the +5V or what? Thanks?
        --Budm: I have power supplies for testing the CCFLs and will do so when it gets dark. In the meanwhile I have ordered another one of those universal 4 lamp inverters from Hong Kong, I am not sure if it has enough connections, but I wanted one on hand anyway. I also have spare bulbs to test the inverter with. I sure hope it is not the bulbs. The last one I had fixed a Star Logic M17ANA Monitor, which I am about to flog on eBay, funds getting short.
        --T&B thanks as usual for your quick and knowledgeable help.
        "If you build a better mousetrap, you will catch better mice."
        Best Regards
        Clear Ether
          BON - connect to 5V but best to use a 100 to 470 ohm resistor in series.
          • SgtRock
            • Feb 2012
            • 175
            Dear Tom:
            --Perfect, thanks. I will report back soon.
            --I have made a couple of attempts at reballing the 380 spot 0.5mm ARM for the 32" Vizio, but no luck yet. Very hard going, so damn small, but will continue to try.
            "Did you ever get the feeling that the world was a tuxedo and you were a pair of brown shoes?"
            Best Regards
            Clear Ether
            • SgtRock
              • Feb 2012
              • 175
              Greetings Badcappers:
              --I found that one of the lamps had gone red. I took the display apart and replaced the bulb with one out of a junker, and now it works. Hooked up to HDMI the screen is stretched out beyond the edges of the monitor. It that probably due to caps on main board, or are there other probable causes.
              "I'll have the Alfalfa sandwich, and the smashed yeast"
              Woody Allen 1935 -
              Best Regards
              Clear Ether
              • ChIck3n
                Dell u2311h 20000 seconds to black issue
                by ChIck3n
                So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                09-09-2024, 11:44 AM
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
                HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                09-12-2024, 02:00 PM
                MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black N4000 Specification for Upgrade or Repair
                This specification for the MSI Cubi N 8GL-063DE/N4000/4GB/W10P/Black can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Cubi N 8GL-063DE/N4000/4GB/W10P/Black boardview and Cubi N 8GL-063DE/N4000/4GB/W10P/Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                09-12-2024, 01:58 PM
                Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                09-07-2024, 05:00 AM
