OEM Bios crossing
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    OEM Bios crossing
    Quick question:
    Is it possible (via BIOS updates or BIOS chip swapping) to convert an OEM board, such as the Board from a HP XW9300, to the clone of the the board, in this case a Tyan K8WE?
    They're the exact same board except the HP one has one less LAN port and also has SCSI (suppossedly an option on the tyan's version).
    Reason I ask is i recently found a XW9300 board for cheap and I was really wanting a K8WE... and if it was convertible by way of a BIOS flash or fresh BIOS chip, then I'd go for it.
    sigpic
    (Insert witty quote here)
  • c_hegge
    • Sep 2009
    • 5219
    Re: OEM Bios crossing
    You can on some boards, but that doesn't mean you can do it on all boards.
    • Evil Lurker
      Warranty Voider
      • Feb 2011
      • 454
      In theory you can, but the boards have to be identical meaning all the IC's have to be the same... usually there are some minor differences between boards. Also, the flash software does a PID check before flashing and if the board is an OEM model it terminates the flashing process.
      What you would probably have to do for a successful bios de-nerfing is to desolder the bios chip and put it on a dedicated programmer to change the PID values. One other possible option would be to figure out a way to put bios chips in some sort of socket adapter and do a hot flash... had to do that a couple times in the past with some boards and it actually does work. Basically you boot up the PC off one bios, yank out the bios chip and replace it with the board still running. That way when the bios flashing utility loads it will read one bios, and right before it flashes you simply swap out ICs.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        there are some flashers that are dos based and you can use some kind of /f to force a flash
        I did such thing on an HP s939 board a year ago. bricked it good
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Yeah, I better not.
          sigpic
          • japlytic
            • Oct 2005
            • 2086
            Another thing to consider is the General Purpose Input/Output (GPIO) pin usage on the chipset - the use of these pins is at the discretion of the manufacturer.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              The boards are literally the same PCB... Exact same PCB.
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I have one of those boards here somewhere, completely forgot about it.....it donated the IO shield to the Frankenserver way back when. That board has a few other differences as well, it has no case header for the buttons, lights, etc, the pins were never soldered in. You could put them in, you'd have to clear the holes and add them.
                FWIW, the HP BIOS has the same features and functions as the OE.....just has the HP splash, which you can disable.... I wouldn't worry too much about the BIOS.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • DynaxSC
                  MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                  by DynaxSC
                  Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                  I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                  11-17-2023, 10:56 AM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • edward card
                  BIOS Request: MSI Raider GE68 HX 14VGG-287US (Board: MS-15M2) - No POST
                  by edward card
                  I'm requesting a working BIOS dump for my MSI laptop, which I plan to provide to a repair technician.
                  Make/Model: MSI Raider GE68 HX 14VGG-287US Board Model: MS-15M2 (Note: I have the serial number ready to be provided to the technician for DMI transfer)
                  Problem Description: The laptop fails to POST. The only sign of life is the GPU fan spinning up after a couple of minutes. The screen remains black.
                  Background / Fault Event: The system was working perfectly. The issue occurred immediately after entering the BIOS advanced menu and exiting with "Discard...
                  10-06-2025, 05:41 AM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
                • Dovakhiin
                  [BIOS Request] Hasee KINGBOOK G97E - Board 6-71-PA7E0-D02A
                  by Dovakhiin
                  I'm looking for BIOS bin files for my laptop. Any help would be greatly appreciated!
                  Laptop Details:
                  • Brand: Hasee KINGBOOK G97E
                  • Model: CPA7504
                  • Motherboard: 6-71-PA7E0-D02A
                  • Part Number: 6-77-PA70ES0A-N02A-3B#1HA2
                  • Board Version: V2.1A
                  • Board Marking: AMI-Aptio NB ©2006
                  Issue: The laptop needs a BIOS reflash for repair purposes.
                  If anyone has BIOS dump files for this board (6-71-PA7E0-D02A) or similar Clevo PA70ES boards, I would be very grateful.
                  Thank you in advance for your help!
                  10-19-2025, 04:05 AM
