ATTEN 8586 Not heating the Iron
  • s_henya
    • Jan 2011
    • 483
    • Israel
    hey guys, got this station for about two years,
    yesterday it stopped heating the soldering iron, the hot air works.
    and i can see this on the screen, any ideas?
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: ATTEN 8586 Not heating the Iron
    i would remove the soldering iron and do a resistance tests across the terminals on the iron, more than certain the element has gone O/C,then if that fails do a voltage measurement from the out put of the station to verify voltage and troubleshoot from there.
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • s_henya
      • Jan 2011
      • 483
      • Israel
      thank you for responding so quickly multimeter, :-)
      i think so too, but before i order a new heating core, or the whole iron.
      between which pins sholud i test resistance,
      and what should i expect.
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        check the red and blue coming out of the white ceramic core,id expect to see fairly low resistance of a few ohms
        • s_henya
          • Jan 2011
          • 483
          • Israel
          out of the core,
          goes 4 wires:
          red and transparent on one side,
          and on the other, yellow and transperent.
          between the red and yellow, i get 20.7Mohm
          does it mean its dead?
          should i order only the core or the whole iron
          (14.83$ for the element, 18$ for the whole iron?)
          station specs:
          http://www.attenelectronics.com/Prod...2/0728/84.html
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 350
            • India
            sir my element is ok still not heating
            • s_henya
              • Jan 2011
              • 483
              • Israel
              hey ravi, do you have the same problem as mine?
              i ordered a new soldering iron for the station
              i will update as soon as i get it.
                • Jul 2011
                • 6070
                Look at page 3
                • s_henya
                  • Jan 2011
                  • 483
                  • Israel
                  hey sam, thank you very much for the link,
                  "Display "S-E" means there is something wrong with the sensor of the working channel.
                  so the device stops outputting signal."
                  i already ordered a new soldering iron for the station, i hope it's not for nothing , :-(
                  any idea what it means?
                  • s_henya
                    • Jan 2011
                    • 483
                    • Israel
                    GOOD NEWS,
                    the iron arrived today and the station is now working again!
                    thank you very much!!!
                    • MDOC
                      EngineeringTech
                      • Mar 2010
                      • 146
                      Look at page 3
                      Somebody does not know English well in China.
