Capacitor Endurance Rating vs. Lifetime
  • mockingbird
    • Dec 2008
    • 5486
    momaka made an interesting statement in a previous thred:
    Originally posted by momaka
    That 2000 hour rating is Endurance, not Life Time. It simply states for how long you can "abuse" the cap with maximum ripple, voltage, and at max temperature (105C in this case) before it goes out of spec or vents.
    Let's say I'm ordering batches of small value electrolytics for PSU re-caps in price-break quantities of around 100+, but I want ones that will have a long lifetime and won't be the weak link in the PSU, is the endurance rating of a particular series something I should take into consideration?
    For example, most 5mm caps endurance rating is below that of wider caps even within the same series. Is a 5mm cap with an 1000 hour endurance rating less reliable than a cap of the same series with say a 2000 hour or more endurance rating, or do they last just as long as their counterparts as long as they are not 'abused'?
    Should I value higher ripple ratings in 5mm caps over endurance ratings?
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Re: Capacitor Endurance Rating vs. Lifetime
    Put in a SU'SCON!
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      If you are running the cap at or near it's maximum specified ripple current, voltage, and temperature rating then yes.
      Basically, the endurance is the life time only when you are running the capacitor at it's maximum allowed specs. Now, for every 10 degrees C drop in temperature below the maximum rating, the lifetime more or less doubles. So if you have some 105C caps rated for 2000 hours endurance, and you are running them at maximum allowable ripple current, maximum voltage, but only at 95C, then their life time will be approximately twice that of the endurance - i.e. about 4000 hours. If you lower the temperature another 10C, the life time will now be 2 x 2 x 2000 = 8000 hours. So basically temperature is what relates the endurance and the life time. The maximum ripple current and voltage probably also have an effect on the life time, but Im not sure how exactly. Well, the ripple current has a pretty big effect on the temperature of the capacitor, so obviously the lower the ripple current in the circuit, the less the cap has to filter and the less it will heat up.
      (By the way, all of the above info is from what I remember from posts made by PCBONEZ. I think he said he read some data sheets on the matter, so all credit goes to him and whoever else may have posted but I forgot to mention.)
      So to answer your question - if you want a long life time from a cap and the cap will be ran in a hot environment, then yes, the endurance would matter.
      Technically, they should be "less reliable". Again, however, if the temperature is significantly lower than the maximum, then the lifetime of both the 1000 hour and 2000 hour endurance-rated caps will be so long that you wouldn't notice any difference - at least not in the useful lifetime of the electronic device these caps are in.
      Depends on the application. In PSUs, I would say no. On motherboards - yes, in most cases (unless it's for a linear regulator, in which case ripple current and ESR are hardly relevant).
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        What momaka said. I'd just add that the "Endurance" or "Life" is what the manufacturer is willing to guarantee (how much does that mean if the cap company is a fly-by-night in another country? to an end user?). IOW, ignoring crap-cap-producers/excreters, that number applies across the entire production population, and many/most of that population would last longer. It's just that if you rely on most caps lasting longer than spec'ed, you've assumed the risk of early failures of caps that only just meet the Endurance spec. And of any consequence from that realized risk.
        PeteS in CA
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          And if you're using cheap caps and just one of them dies, doesn't it create a chain effect because then the other caps on the circuit have to work harder to make up for the dead cap, killing them faster?
          • PeteS in CA
            • Aug 2005
            • 3583
            To at least some degree the AC current, the ripple current, is a constant current source. So unless the dying cap dies dead short, each remaining cap in the parallel network "sees" an increase in its share of the total ripple current. So, yes the remaining caps are stressed more, hastening their demise, whether premature or just sooner than intended.
            PeteS in CA
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              What PCBONEZ also said that is that cap manufactures expressly state those endurance ratings with 60% confidence in the datasheet (given the failure rate)... I think mariushm said that too... so a capacitor that is rated at 6,000 hours @ 105*C could be in actuality anywhere from 3,600 hours or 10,000 hours... of course, it's still better to use capacitors with higher endurance ratings so the worst case scenario isn't a terrible one. As for linear regulation - I always thought that wasted lots of power, lots through the capacitors, so while that sort of DC-DC converter usually provides a very clean output noise and ripple wise, I would still think it's tough on the capacitors.
              The main problem with Taiwanese brands is that the quality of aluminum foil is so poor (too much copper or other impurities) that it isn't difficult for those impurities to leech into the electrolyte and you know the rest. When that happens, it won't matter if the capacitor is rated at 20,000 hours @ 105*C, it's done. Internal heating, or ripple current, or external sources of heat do exactly that, even in the most minimal manner (if you can keep the ripple and heat down, though, it may never happen). Some of these "better" brands probably do better in PSUs because it's easier to give them ample airflow in such a design and a good design will result in little ripple current. Also note that the end ripple voltage (what you see measured in millivolts on each rail) and the actual ripple current going through the capacitors isn't the same thing. While the end ripple (going to the motherboard) could be low the actual ripple going through the capacitors is much higher, often thousands of milliamps (it has to be "dumped" to the ground through low ESR capacitors so it doesn't "escape" to your system), so ripple rating is very important, IMO.
              • mariushm
                • May 2011
                • 3799
                Linear regulators waste a lot on the pass transistors inside the regulators themselves, capacitors don't get too much stress.
                However, it's important to use adequate capacitors so as to not get the regulator unstable, some regulators need capacitors to have esr within a particular range, or lower than a value, otherwise they'll oscillate.
                See page 18 and onwards, but the whole app note pdf has good info.
                I don't remember the 60% value and honestly it seems kinda low. A value of about 80% wouldn't surprise me.
                Either way, everyone recommends using capacitors rated for at least 50% larger voltage than the voltage the capacitors will work at and so on.
                With ceramic capacitors - which may be tempting due to very low esr - it's even more critical to use proper capacitor as the capacitance of ceramic capacitors decreases A LOT with the voltage.. a 10uF 16v could have only 0.5-1uF at 10v. Usually, it's recommended to use 5-6x times bigger voltage rated caps when using ceramic capacitors
                • bruce14120
                  • Mar 2013
                  • 2
                  • u.s.a.
                  So, If I cool the power supply caps in my LCD HDTV with a cooling fan I should be able to reduce the ambient temperature significantly and extend the life of all power supply components. Likewise, if I need to replace caps I should be able to use high quality 95 degree caps. Makes sense to me!
                  • chth96
                    Is it no harm to replace with capacitor without ripple current rating?
                    by chth96
                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                    Rubycon YK DataSheet (b...
                    04-19-2024, 05:19 AM
                  • quickname
                    Cyberpower 1500AVR UPS repair
                    by quickname
                    I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                    Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                    I decided to verify that the batteries were...
                    11-12-2023, 09:57 AM
                  • Perry Babin
                    Electrolytic cap endurance
                    by Perry Babin
                    From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
                    Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
                    Why do polymer capacitors...
                    10-18-2025, 05:21 PM
                  • ADV
                    Acer Ferrari F-20" monitor display interference and replacement capacitor selection
                    by ADV
                    Good day everybody
                    I hope I'm posting in the right section - I am new to this awesome forum.
                    I have received an ACER Ferrari F-20" LCD Monitor to repair.
                    It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
                    For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
                    I opened the external 18V power supply and see no bulged capacitors...
                    11-02-2021, 09:32 AM
                  • Antonynl
                    What are typical ripple voltages on a laptop motherboard?
                    by Antonynl
                    I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                    So I have two questions:
                    1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                    2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                    Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                    12-09-2022, 06:51 AM
