Identifying Nichichon Capacitors from Mouser...
  • ran
    • Oct 2006
    • 71
    Hi everyone.
    As per the stickied FAQ (yes, people *do* read it, though it might take them a little while to find it...) and some helpful suggestions in another thread I posted, I am trying to locate NiChicon Capacitors to replace in my PS.
    However, as an example, if I look for 1000uF, 16/25v Nichicon radial Caps from Mouser, these are the model #'s I get:
    UVZ1C102MPD
    UVZ1C102MPH
    UVZ1E102MPD
    UVZ1E102MPH
    UBT1C102MHD
    UBT1E102MHD
    Now, I can't seem to match up any of these letters with the typical '2-letter' series y'all keep mentioning, so does this mean that Mouser is not a good source for the caps I want?
    e.g. Nichicon PM (lead-free version of PL), PS (lead-free version of PR), PW, or HE (the latter two preferred over the former) (from Pete S.)
    Also, the only "low ESR" (keyword search) capacitors I can find at Mouser are from "Xicon"...are these any good?
    Should I look elsewhere (e.g. Digikey?)
    Integrity - doing the right thing even when no one is looking
    Freedom - not the right to do as you please, but the liberty to do as you ought.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Identifying Nichichon Capacitors from Mouser...
    digikey catalogue is ok
    • Spacedye69
      • Nov 2005
      • 698
      • US
      Look under "low impedence" catagory. Mouser stocks both PW and HE in that size, but they are 10mm dia.
      • ran
        • Oct 2006
        • 71
        Yeah - I figured that out, eventually. I used some cat #'s I got from Digikey (they have "low ESR") and then found that mouser had those series under the low impedance category...so I'm good!
        Thanks, all!
        Ran
        • PeteS in CA
          • Aug 2005
          • 3578
          • USA, Unsure of Planet
          The VZ series is a GP 105C series, nice for GP decoupling capacitors. The BT series compares well to the PW series for the parts you cited, but the BT series is rated for 125C use instead of 105C, so those would probably be suitable for P/S use (Nichicon recommends them for automotive use).
          PeteS in CA
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            It will start to make more sense when you open the data tables in the links at mouser/digikey and compare the caps by their ESR and Ripple ratings.
            Lower ESR is better
            ESR can be thought of as how much 'resistance' the cap has to passing Ripple.
            Higher Ripple is better.
            The Ripple rating is how much Ripple it can pass without overheating.
            Terms like "Low ESR" "Very Low ESR" "Ultra Low ESR" are marketing terms that have no 'official' technical definitions and so are used rather loosely.
            One manufacturers "Very Low" may be anther's "Ultra Low" and yet anther's "Low".
            What you should do is look-up the ESR/Ripple of the old caps and try to meet or beat those specs.
            Mann-Made Global Warming.
            - Dr Seuss
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              thread necro
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Yeah but he still hasn't figured it out.
                https://www.badcaps.net/forum/showpo...5&postcount=78
                https://www.badcaps.net/forum/showpo...7&postcount=80
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Moved here:
                  https://www.badcaps.net/forum/showthread.php?t=6632
                  - Dr Seuss
                  • Toasty
                    • Jul 2007
                    • 4171
                    Ran,
                    Good to see you're in a new thread. I just wished you'd gone into the detail like you did in the other thread from whence you came. i.e. - why you were doing this cap search
                    Interesting. I think the same thing happened on my G5 Imac 1.6ghz machine.
                    Would draw the attention of those that deal with this problem, not only here but in web searches. Getting "iMac" & "G5 power supply" in the thread title would draw them in like flies to honey.
                    Also, Wizard may be interested in your supply BEFORE you mess with it.
                    Once the repairs are completed, I and others will be interested to know if you have the same problems with the coil overheating as in the other thread.
                    Toast
                    Geeze! I just got done and its moved already. What is this? Whack-a-Mole??
                    veritas odium parit
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      Originally posted by ran
                      UVZ1C102MPD
                      UVZ1C102MPH
                      UVZ1E102MPD
                      UVZ1E102MPH
                      UBT1C102MHD
                      UBT1E102MHD
                      Yeah those aren't series numbers they are series manufacturer part numbers.
                      They correlate with the series, size, lead spacing, capacitance, and voltage.
                      They are great when you have to reorder a specific size and series of cap though.
                      You want to find a low ESR series for the cap company you are looking for and filter your search by series. Then look up the datasheet for that series to see the sizes available a link is usually available on the parts page.
                      I use a digital caliper to measure the caps I'm replacing if space is tight. You will eventually get accustomed to the design of your cap companies datasheets I am very familiar with Chemicon's and Panasonic's my big two cap companies I use.
                      Funny you mentioned Nichicon VZ series I just bought one a 4700 uf at 63V for my new Mastech linear PSU to replace a counterfeit Chemicon. Luckily it's a linear so GP will do. Digikey was out of the Pana TS-HAs so size wise they were all I could get.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Originally posted by PCBONEZ
                        MOVED HERE
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          This thread was started Oct 2006.
                          Current/new one by asker is through link above.
                          - Dr Seuss
                          • varkatope
                            Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
                            by varkatope
                            Hey there, retro fans.
                            I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
                            12-15-2024, 09:48 AM
                          • dragon3x
                            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                            by dragon3x
                            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                            power on.
                            Here are some examples :
                            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                            switching supply area).
                            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                            than 6.3 V.)
                            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                            I replaced capacitors with aluminum-polymer.
                            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                            03-21-2025, 02:46 PM
                          • DrewPhillips
                            Capacitor Diarrhea - Nichicon PL Series
                            by DrewPhillips
                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                            03-02-2025, 10:18 PM
                          • burom
                            Xbox 360 Xenon Modern Capacitor Replacements
                            by burom
                            I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                            I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                            06-07-2024, 05:10 PM
                          • xnRS
                            Exactly same capacitors from NCC and Nichicon
                            by xnRS
                            I was searching some caps and found NCC KY and Nichicon UHE. I was looking for 1000uf 10v 8 x 20 mm. If you'll look into data, you'll see that impedance at 20 and 10 degress celsious is same, same applies for the ripple current. Also, I saw same thing with some other big caps(680uf 400v, or something like that, don't remember exactly) and saw same thing from NCC and Nichicon, no other manufacturer. This leads me to one idea - they are using same factory and just rebranding some caps.
                            Any opinions on this one ?
                            10-15-2021, 03:23 PM
