So I have been following the other threads here on troubleshooting the 50 inch Panasonic version. It looks to be the same or very similar to this 2009, 42 inch chassis.
So I pulled the ribbon cable and power cable (SC20 & SC2) off of the SC board and was able to get the 6 blinks which looks to be a bad SC board. Pulled the upper and lower buffers and removed the SC board and did some in circuit testing. Q452 (Q16452) an NPN power transistor was open in all directions on the 10 Meg scale. Looks like this would impact the FET driver signal in some way so I am guessing THIS IS A BAD THING! (The FETS appear to be OK in circuit) No shorts.
Part number for the NPN is 45G127 which is absolutely nonexistent!! No cross anywhere! I found a link to a Chinese distributor for the exact part but obviously no specs, however it was really cheap! So I went with my gut and found the cheapest T0-220 NPN power transistor at Radio Shack (TIP31 or 276-2017). I had to mount this with an insulator pad and screw as the original was self insulating. Put It all back, fired it up and got a "pulsating" red light for about 10 seconds then it went out. Never got picture or any screen action.
Now I'm back to 8 Blinks!! I am guessing I blew the NPN again. I am waiting for my parts dealer to try and cross it with his database tomorrow. I have about half a notion to pop in a 90W NPN which is Mo Power than the 40W i tried first!
Any thoughts would be appreciated! Cheers..
