Sony KV_21M1D (BE-4A) image reddish
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I checked all the caps and replaced 4 that had higher esr than normal.
    I checked for cold solder joints and reflowed when necessary.
    I also checked the transistors on the board connected to the neck of the tube and found nothing shorted or open.
    Yet, the image is reddish.. I don't know what to look for and I could really use your experience guys.
    2 photos of the CRT image attached
    Re: Sony KV_21M1D (BE-4A) image reddish
    I have seen this before, I do not repair CRTs, but I believe the tube is ageing, it is repairable though by tweaking the red level down, but I can't remember where that is done.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      I believe they usually have potentiometers to change the color levels. Sometimes they are outside of the TV, but most of the times (on more modern CRTs) they are inside, and the TV will have to be opened to do this.
      Muh-soggy-knee
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Had a 2005 RCA CRT TV look like that. It's in snow out back now! I tried it during early June, 2012.
        And my cold-power-on test failed!
        It would turn off by itself when I turned it on after sitting!
        RCA appears to be crap now. I wouldn't be surprised one little bit if their LCDs are even worse!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          This is the service manual. I could try to change the red levels from the service menu. Are you sure this is a tube problem?
          • RJARRRPCGP
            • Jul 2004
            • 6304
            I was given a TV that also had the same type of problem, even though the blues mostly looked fine, the red seemed to not affect all areas.
            I was gonna keep the 2005 RCA CRT TV until I found out that it keeps turning itself off! Just like I pressed the power button!
            Appears to be a common RCA problem! Once saw a video with the same type of shut down on YouTube, IIRC!
            Possessed like a daemon's in there!
            Arc A770 16 GB
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              Turns out that the green color is dead. I think it is the tube. I tried to correct the image through the service menu, but I can't do much... It is blueish or reddish or both. And the only settings that worked gave really dark/fuzzy image. This TV is not fixable.
              • domix
                Sony KD - 65XF9005 - No image, sound OK
                by domix
                at tv KD - 65XF9005 i have a problem.
                Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                is this a common problem for this tv?
                i attached pictures of inside. Supply board looks okey, no blowed caps....
                07-21-2025, 06:37 AM
                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:20 PM
              • Dreamcazman
                Sony KV-XJ29M31 CRT TV - Very dim image on turn on
                by Dreamcazman
                Hi all, I recently picked up a Sony KV-XJ29M31 CRT TV (BG3R chassis, Australian model) cheaply & completed the RGB mux mod on it for some retro gaming. That worked great, however, I have another problem which I hope someone can help me with or at least steer me in the right direction.
                Basically, the issue is when it's cold, it takes a while (like 2 mins) for the picture to come up. I think the image is there, it's just very dark or dim. I can hear the degaussing sound & I can change inputs & hear audio but no image.
                Once it's running properly, it keeps...
                02-28-2022, 07:47 PM
              • x_orange90_x
                Sony KD-60X690E 6 Blinks, no image
                by x_orange90_x
                I just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
                I...
                12-10-2024, 09:10 PM
              • Jaime Morillo
                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                by Jaime Morillo
                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                The TV was stuck on the logo and I couldn't access the update menu.
                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                The image result was good, but the image is inverted.
                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                08-18-2025, 11:38 AM
