Compaq v3000 touchpad blinking with beeps sound
  • sasser
    • Dec 2012
    • 364
    • Malaysia
    i got 1 motherboard compaq V3000 were touchpad continues blinking also got sound 1 long beeps 2 short beeps. sometimes can boot until windows logo. sometimes hang at bios step. are this problem cause from failure BIOS . any idea ? i really from bios failure im ready for flash the bios.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Compaq v3000 touchpad blinking with beeps sound
    vga problem 99% same as dv2000/dv6000/dv9000
    Im Back... sort of...
    • sasser
      • Dec 2012
      • 364
      • Malaysia
      This board not hav vga like dv2000 or intel chipset problem. Sometime hav display sometimes sound beep with no display. Anyone else face this problem before. I try check again exacly model board is v3629TU
      • gabik111
        ORD spotter
        • 142
        • USA / Poland
        1 long and 2 short beeps are related to video issue. Try to heat GPU by a hairdryer or if you have hot air and you will see. Propably needs reflow.
        Laptops and computers repair.
        • sasser
          • Dec 2012
          • 364
          • Malaysia
          Thanks to reply the compaq presario v3629tu graphic chipset use Intel Graphics Media Accelerator X3100. So i need reflow this chip?. What yr advice gabik111? Reball or just reheat the chip.
          • gabik111
            ORD spotter
            • 142
            • USA / Poland
            Well , reballing is the best choice but sometimes only reflow will help and it will last long. Depends on working enviropment if reflow will help it will be good.
            Every laptop is a single problem. Each one need separate attempt and cannot be treated as common issue. Similar issues can point you where and how to look for damages.
            • sasser
              • Dec 2012
              • 364
              • Malaysia
              Already flow but still the same i reflow the chip intel in circle. Charging light flash also button touchpad blinking
              • sasser
                • Dec 2012
                • 364
                • Malaysia
                I still can enter bios but hang at this step or when got window logo the system just loading cant enter window anymore. Please help
                • heavymachines
                  • Mar 2011
                  • 1028
                  sounds like its not all the way bonded after reflow..
                  • valiant007
                    Comp Technician
                    • Dec 2012
                    • 44
                    • philippines
                    did you try cleaning the memory with an eraser or using another memory. the beeping sound was a video chip prob but the hanging prob could be the memory. wont hurt to give it a try.
                    _________________________________________________________________
                    Free Computer Service!!!!!!!!!
                    If We can´t Fix the problem.
                    • sasser
                      • Dec 2012
                      • 364
                      • Malaysia
                      Yes before reflow i changed processor also try another ram but still blinking. Usually if bad ram no display but i can see normal display.
                      • sasser
                        • Dec 2012
                        • 364
                        • Malaysia
                        solved this cause of power failure
                        • trebo
                          • 514
                          • Wales, UK
                          Hello sasser
                          Can you tell us what the fix was Please, others may need the help
                          • gv7429
                            • Mar 2013
                            • 3
                            • Singapore
                            Hi
                            I have a Compaq Presario V3638TU showing the similar symptoms.
                            Using the power adapter with the battery removed, the front Power light blinks. When I pressed the Power button, the notebook gives out 1 long beep and 2 short beeps continuously. The fan is running. The display is blank. The front Power light is blinking. The TouchPad light alternates amber and blue. The Media button, Volume Mute button and the light near the num lk is on.
                            Using the battery only, the symptoms are as above but the COMPAQ startup screen is displayed briefly before the screen goes blank. If I pressed and released the Power button, the notebook switched off and turned on again but this time without the COMPAQ startup screen unless I do a hard reset by removing the battery and pressing the Power button for 15 seconds.
                            Hello Sasser, can you share with us what you did to resolve this? Thanks.
                            • masud
                              • Jul 2011
                              • 317
                              • Bangladesh
                              try for a bios write.
                              • gv7429
                                • Mar 2013
                                • 3
                                • Singapore
                                Hello masud
                                Thank you for your suggestion. I tried HP procedures on recovering the BIOS using key press combination without success.
                                I think this is a hardware fault. With the battery and power adapter inserted, the notebook cannot power up. No light, no display, only the right side power connector light is on.
                                • gv7429
                                  • Mar 2013
                                  • 3
                                  • Singapore
                                  Originally posted by gv7429
                                  Hi
                                  Correction. The front Battery light blinks not the Power light. Both Power light are off. I suspect it may be the charging circuit as the Battery light blinks when the battery is not inserted.
                                  • spleenharvester
                                    • Mar 2010
                                    • 903
                                    Out of interest has anyone actually seen an Intel GPU fail? I've never seen it in all the years of doing board-level repair.
                                    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                                    • bachtiar
                                      • Feb 2014
                                      • 1
                                      • indonesia
                                      Hello sasser... i have the same problem..Can you tell us what the fix was Please...
                                      • sunilnjarakkat
                                        • Dec 2013
                                        • 13
                                        • u.a.e
                                        Bios problem
                                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 03:36 PM
                                          HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:30 PM
                                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
