LG 50PK550 Full HD 50" Plasma - sound, no picture
  • tw2005
    • Oct 2011
    • 6458
    Hi, I thought I'd share this unusual failure. I picked up a nice 18 month old LG with sound, no picture.
    Expecting the worst case like damaged Y-main and buffers I first isolated the upper buffer with no change.
    Then swapped around but left the lower buffer connected to the panel but no input from the Y-main.
    Got a picture but the bottom was really behaving weird and messed plus I started to hear arcing and that dreaded component burning odour. It was comming from the very bottom and I'm thinking great, you just destroyed the panel. Maybe leaving that panel connected the bad buffer was not so smart.
    Anyway removed the bottom buffer and what do I find? One very crispy cockroach and a hole burnt right through the board below the last buffer IC.
    The person I got it from was pretty annoyed with LG as it was just out of wty and they would not offer any goodwill.
    It appears to me that in this instance LG were not to blame but the cocky.
    From what I can find this was a $1600 TV here in Australia when purchased.
    Re: LG 50PK550 Full HD 50" Plasma - sound, no picture
    Another bug found? Incredible. I had a 42" go down due to a bug trapped on the buffer ICs, too!
    • tw2005
      • Oct 2011
      • 6458
      What brand? I'm wondering if it would be smart to somehow tape over these points because there is very little clearance between the buffer and panel.
      This set is incredibly thin!
        It was a Panasonic. A tiny little moth looked a little crispy.
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • SluggerB
          LG Plasma (PDP50R10101) No picture No sound
          by SluggerB
          This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
          So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
          Following a YouTube videos...
          12-03-2022, 09:10 PM
