Magnavox 42MF521D/37 42-Inch
  • Vizor
    • Nov 2011
    • 215
    History
    my little bro purchased This off facebook about a month ago and tried to fix it himself he replaced a few caps around 2018 but still no luck.
    Symptoms
    TV doesn't turn on, no Light nothing
    Power supply comes on but chirps and gets hot at 2 p6Ke120A's
    Analysis
    1) i think the power supply may be bad.
    2) not sure about the main board but it has a bunch of brown stuff all over the board.
    Re: Magnavox 42MF521D/37 42-Inch
    I believe this is caused by a shorted TVS near 12.jpg. With no power applied, check the diodes for shorts using the diode test mode of a multimeter. The diodes are the black devices with a white band, e.g. 6054.
    • Vizor
      • Nov 2011
      • 215
      Looks like all 5 of those Diodes in that picture are shorted.
        Do they read the same both ways?
        • Vizor
          • Nov 2011
          • 215
          All of them but 6066 have the same measurements both ways.
            Okay, that sounds pretty shorted to me. Do you have the ability to remove the diodes, is there a part # on them?
            • Vizor
              • Nov 2011
              • 215
              p6Ke120A on 2 of them was just making sure they were shorted before ordering some new ones, suppose their is probably nothing locally to use.
                Yeah, that's most likely a Digikey thing to order:
                http://search.digikey.com/us/en/prod...ACT-ND/2770358
                Still, ~$5 to fix a TV... not bad...
                • Vizor
                  • Nov 2011
                  • 215
                  gonna be a little bit more then that gonna replace all the caps just to make sure
                    Good idea. These Magnavox PSUs kill caps like no other. I would suggest Panasonic FM or FR replacements.
                    • electronicsurplus
                      • Jun 2012
                      • 210
                      Also, we have found that even though the caps are replaced and the Diodes are not shorted. since, the diodes are fast recovery they still need replacing
                      Sometimes the power supply will chirp. This is coming from the Transformer not turning on due to defective Diodes. We have used ECG156 or equivalent. work perfectly and, are available at most electronic distributors. we buy them by the 100's @ .50/each
                      Just thought this may help a few people
                      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                      Help keep these from the landfills
                      • cliff_hootarski
                        • Jul 2006
                        • 411
                        Just repaired one of these last week. Replaced the two zener diodes 6055 and 6054, and
                        the 3 1500mf caps on the secondary side. Another post here mentioned that the two zeners
                        could be replaced with Radio Shack #276-1114 1.5A/1000v diodes. Tried that temporarily
                        and the set fired right up. Ordered the correct zener diodes from Digi-Key for the permanent fix.
                        (original symptom of the TV was the power supply chirping noise and voltage varying).
                        • Jonny Accelerant
                          Banned
                          • Aug 2014
                          • 205
                          I have an opportunity to buy one of these broken from craigslist, unseen. What's a fair/safe price to offer for it. If it's a matter of caps and diodes I can fix it.
                          • tonybig10
                            Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                            by tonybig10
                            Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                            the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                            03-07-2025, 01:03 PM
                          • Gibon378
                            What caused the BSOD?
                            by Gibon378
                            Hello there!
                            I was doing some usual stuff, browsing the internet, listening to music, coding, etc. and my computer froze. It looked like the website couldn't process the request (logging into the account, there was the loading symbol) and it took a few seconds, then my computer totally froze except for the mouse cursor. It lasted for about a minute and I got the BSOD. It happened yesterday and today (just now).
                            I managed to get the MEMORY.DMP content, but I don't really understand it. Could somebody help me?
                            Code:
                            ************* Preparing the environment for Debugger
                            06-23-2023, 06:20 AM
                          • Uranium-235
                            SMD coil whine "chirps"
                            by Uranium-235
                            Does anyone have high frequency sensitivity hearing and a motherboards have tons of sounds coming from it? Is this just coil whine en masse? When data to the SSD has high I/O I can hear the clicks and chirps. Same with when the graphics drive inits. Network adapters, chirping after I connect the cable
                            I can hear everything. Every time I put my ear to let's say an open Shuttle XH series pc (currently working on) in the next room it sounds like I'm in the middle of a the fucking public bird aviary
                            Of course this isn't just the shuttle, though I think the small case...
                            07-10-2023, 10:06 PM
                          • sudz28
                            Magnavox 27MS5402/17 CRT - no picture, flashing green light
                            by sudz28
                            I'm going to assume my beloved Magnavox CRT is toast, but also figured maybe this was a good opportunity to dip my toes into he circuitry waters and maybe learn something new. Also, I don't want to trash it if it's a fairly cheap/easy fix!
                            My 20-year-old Magnavox has gotten me and my kids through many a gaming console change and worked great up until the other day. Following a long distance move, it sat in our garage for a year and now that I brought it in and turned it on I get no picture; instead, a green light blinks on the front of it; 7 flashes, one long flash, then 3 more...
                            02-08-2022, 10:09 AM
                          • barrybahr
                            Magnavox 32MD350B/F7 getting a false on/off control voltage
                            by barrybahr
                            The unit is stuck in an intermittent on/off cycle. When I plug in the power cord, the green "On" light activates without any command, flashes for a few seconds, then turns off. The red standby light comes on for a few seconds before the cycle repeats. During this time, I cannot turn off the unit manually; it will shut off automatically after about five minutes, and there is no picture. Occasionally, with repeated attempts to power it on, I eventually get a picture and sound, which function properly. When it does work, I measure several voltages, and they appear to be normal....
                            04-20-2025, 10:30 PM
