Can anyone help me with obtaining a service manual for a LN40B500P3F samsung tv? Thank you!
samsung LN40B500P3F
Re: samsung LN40B500P3F
Does the backlight come on when you unplug that ribbon cable from the inverter/power supply board? Inverter ON/OFF pin should have >3V same for PWR ON/OFF PIN when TV is turn on. Your DC readings are OK.Last edited by budm; 10-18-2012, 02:00 PM.Never stop learning
This is a Black Friday special, a variant of the LN40B530 I believe.
Uploaded manuals here:
http://tgohome.com/ServiceManuals/?d...&Search=Submit
Please note, there are at least two variants of this chassis, N70A and N64B. Check the model code precisely for the right variant.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Your power supply/inverter board is OK, you will have to troubleshoot the main board next, the inverter ON/OFF signal from the main board is not working, it is stuck in the LOW (Off) mode.Last edited by budm; 10-18-2012, 02:45 PM.Never stop learning
model code is
LN40B500P3FXZA
I guess i dont see the manual or its not there
here is a closeup of main board if that helps. I dont know if theres much i can do but the only main board i could find was $90 so hopefully i can fix it with your help.
main board is BN94-02746KLast edited by ryan74; 10-18-2012, 03:05 PM.
Wow, tiny main board.
Check the manuals I linked to, they are B530, but they might be the same.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
maybe im too tired. i understand the test process for main board i think but the test points dont seem labeled the same as the manuals. all the test points i see are marked TP*** (3 digit numbers)
if im going to figure out whats wrong i need to be walked through this one. smallest board i have attempted to fix and i dont know what half the parts are on it lol.....
http://www.populargaragesale.com/pgs...product_id=747 - Says not working? Or maybe untested?
http://www.ebay.com/itm/SAMSUNG-LN46...-/200828359389 - Insane price!
http://www.ebay.com/itm/SAMSUNG-LN46...-/200828359389 - Same part from Emerson TV?Last edited by tom66; 10-19-2012, 01:54 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by ryan74 View PostThe links you posted look like the right part but numbers don't match. Are you sure, these are compatible.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
You can contact Shopjimmy to see when he will have them instock again:
http://www.shopjimmy.com/catalogsear...ng+ln40b500p3fNever stop learning
I contacted shopjimmy they couldn't say whenor if they would restock.
I also contacted samsung support. They knew less than me. They were unaware of any replacment but shopjimmy says either bn94-02746k or bn94-02746y will work.
Unfortunatly I cannot find either in stock for less than $90+shipping used and I forgot where I found it. LolLast edited by ryan74; 10-19-2012, 01:07 PM.
Originally posted by budm View PostYour power supply/inverter board is OK, you will have to troubleshoot the main board next, the inverter ON/OFF signal from the main board is not working, it is stuck in the LOW (Off) mode.Last edited by ryan74; 10-19-2012, 02:10 PM.
The transistor on the main board is on so the output will be low (the transistor may be told to be on due the bad processor or bad transistor), the pull up resistor is in the power supply board thst is why when you remove the cable to the main board, the power supply and the backlights turn on due to the pull up resistors on the power supply board are pulling the pin high.
What we need to do is to find out next if the only circuit that is bad is the Inverter ON signal or it may have more than one problem. Waht you can do is to disconnect the Inverter on wire only for the the board so the backlights will come, if everything else is OK, hten you should be able to see the pictures and sound from the TV. If not, then you have multiple problems with the main board. The whole purpose of the backlights is to give the light source so you can see pictures, it does nothing else, so try that.Never stop learning
You can cut the wire then you can splice it back together when we fix other problem, just make sure to cut the right on and also tape up the ends.Never stop learning
