Abit KA7 with bad NICHICON caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    KA7 with bad caps, no surprise....
    However, this one was recapped by someone else using Nichicon and Teapo caps.... Surprisingly, the Nichocons were bloated and bad as well as the Teapos...
    I recapped it with Rubycon 10v caps instead of 6.3v caps, and it now runs perfectly... It hopefully it lives a bit longer... The only possible explaination for the failed Nichicons would be that the board was in a case with little to no ventilation, and they overheated. The caps by the CPU slot do get very hot under normal operation.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    were the nichicons low esr?
    strange.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      They're not marked 'low ESR', although, I've never seen a Nichicon that was. The caps are marked:
      Nichicon
      1500uF
      6.3v
      105*
      HD(M) series
      The guy sent me 2 KA7's, one had the vented nichicons and the other had the stock JPCON caps (vented of course). Both boards have been running for 2 days now, no problems since recapping.
      Team : 49813
      Join in!!
      Team Stats
      • strife667
        • May 2004
        • 3
        bad nichicons
        OMG, and I just recapped my Shuttle AK31 with similar Nichicon caps (1500uF, 10V, HE(M) model) :o
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          That array of Rubies is a work of art.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i have seen nichicons bulging/leaking in gm/bose speaker amp boards.
            85c caps in a black on black vette?
            no wonder they died!
            • strife667
              • May 2004
              • 3
              Originally posted by Topcat
              Nichicon
              1500uF
              6.3v
              105*
              HD(M) series
              just wondering... they used 6.3v caps to replace the old ones, were the original rated 6.3v or 10v? can this difference have some influence in endurance?
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                Thanks! I FINALLY found a vendor with quality Rubycon 8mm caps, after a year of hunting. It looks a lot more professional than the 10mm rebuilds!
                The 10v caps can simply endure 3.7v more than a 6.3v. The temperature limitations and tolerances are the same. If the 6.3v caps were pushed close to their limits on voltage, using 10v caps might extend the lifespan. With the failed Nichicons in the KA7 above, I personally think they had overheated due to lack of ventilation in the case. Failing Nichicon caps is not a common thing.
                I've seen the same vented Nichicon 85* caps in Bose amplifiers in Nissan 300ZX's. You'd think a company with the reputation of Bose would use higher rated caps.
                Team : 49813
                Join in!!
                Team Stats
                • flobot
                  • Jan 2005
                  • 2
                  i also have an abit ka7-100
                  caps, also leaking... they are all JPCON
                  but i noticed that on the image above, (the first one) the taller caps pictured in the group of 4, are rated at 1500uF, while the ones on my board are rated at 2200uF, ive already replaced all of my 2200uFs with new ones, as they showed the most bulging and leaking..
                  and another next to the dimm slots (the outside edge right in the middle below two other 2200uF caps)
                  my question is then should i have replaced the 8 caps that were 2200uF before with 1500uF ones?
                  i also ask this because i noticed that the replacement cap kit from the main site contains no 2200uF caps whatsoever but 24 1500s
                  hmm bad move? guess i found this site a bit late... though i doubt you ship to europe...
                  i just bought these caps at my local electronics shop, cant really tell if they even have a brand name, they have 'NA' where the name is usually located
                  • bushytails
                    Moderator
                    • Dec 2004
                    • 217
                    Using oversized (in terms of microfarads) caps is OK, and in fact improves stability on some boards.
                    --Randy
                    • flobot
                      • Jan 2005
                      • 2
                      ok... well i just want to be sure, i thought that uF values shouldnt be changed.. that only voltage could be (higher that is)...
                      also should i replace all the 1500uF caps? most 'seem' ok... there were only 2 that were leaking, granted the others could still be bad...
                      one other question. which two 1000uF caps would be the ones replaced by the ones included in the set?, i noticed that only two 1000s are included. but theres more than that on the board
                      • nick3092
                        Mid/late 80's Nichicon Yellow Caps
                        by nick3092
                        I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                        08-28-2022, 03:56 PM
                        Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                        by momaka
                        I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                        For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                        https://www.badcaps.net/filedata/fetch?id=3591771
                        https://www.badcaps.net/filedata/fetch?id=3591772
                        It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                        https://www.badcaps.net/filedata/fetch?id=359177...
                        03-12-2025, 03:42 PM
                      • eryjus
                        Heathkit IO-4205 Power Supply Caps
                        by eryjus
                        First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                        I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                        I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        Identifying caps on an old Zoom 9000
                        by Paxman_Swede
                        Hello!
                        I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                        The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                        I have studied the board and...
                        01-14-2025, 09:51 AM
                      • captain150
                        Help with switching power supply caps
                        by captain150
                        I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                        I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                        03-16-2025, 07:34 PM
