Marking on electrolytic capacitors
  • debjit625
    • Jan 2012
    • 14
    Hi this is my first post...
    I was looking over a motherboard and I found some electrolytic capacitors, radial lead types having marking of "221 16V" I guess it is 220 micro farad 16 volt,but I never seen this kind of marking on an electrolytic radial lead capacitor PTH types,its very common on SMD electrolytic capacitors.
    Their are some more capacitors and their marking are like these "K581 6.3V" it may be 580 mfd and "K681 6.3" it may be 680 mfd.
    I can check them but I am asking you guys first...
    Am I correct?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Marking on electrolytic capacitors
    Best guess.
    220uF 16v
    680uF 6.3v
    There is no standard [industry requirement] for the marking method.
    They can use any method they want on any kind of cap.
    At first direct printing was least expensive way.
    Then using sleeves became less expensive.
    Now direct printing is cheaper again. [More advanced printers.]
    ~ But most factories are already set up to support using sleeves.
    Mann-Made Global Warming.
    - Dr Seuss
    • debjit625
      • Jan 2012
      • 14
      Thanks...
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        If you show some photos someone might recognize the brand.
        [If you care.]
        - Dr Seuss
        • Agent24
          I see dead caps
          • Oct 2007
          • 5069
          • New Zealand
          I'd be interested in seeing a photo, never heard of electrolytics using 3-digit codes before either
          -David VanHorn
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Common on ink marked caps.
            Also very common in the part number in the data sheet.
            Like so
            R33 = .33 uF
            3R3 = 3.3 uF
            330 = 33 uF
            331 = 330 uF
            332 = 3300 uF
            See Part Number column.
            - Dr Seuss
            • debjit625
              • Jan 2012
              • 14
              It's a running motherboard with no problem ,so I don't want to desolder the capacitors.
              Some how I managed to take a few photo while they were on the board...
              Its a Zebronics motherboard old 845 chipset (GMCH) with P4
              http://www.zebronics.com/
              As I am learning to repair motherboards ,I just gave a look on it for better understanding of older motherboards.And I found it weird...
              • Agent24
                I see dead caps
                • Oct 2007
                • 5069
                • New Zealand
                Well if they look like the ones in your photos then it does have a problem, and it won't be running for much longer
                Like so
                R33 = .33 uF
                3R3 = 3.3 uF
                330 = 33 uF
                331 = 330 uF
                332 = 3300 uF
                But yeah, I've never seen aluminium can electrolytics without sleeves marked with a code rather than straight values like that before - you certainly do learn something every day!
                -David VanHorn
                • mariushm
                  • May 2011
                  • 3799
                  I think both have issues.
                  The second is obvious, swollen... replace it. I think that one's 580uF 6.3v.
                  The one in the first picture looks to me like it's bottom is coming out, maybe inside gasses pushing it outside.. if so it's going bad so you should replace it.
                  If you want, post one or several pictures of the board, maybe our eyes can spot other possible issues or faulty capacitors.
                  Also keep in mind that if that capacitor is swollen chances are the ones in the same area were also abused in the past and on their way out, so you may have to replace others even if they look good.
                  • debjit625
                    • Jan 2012
                    • 14
                    Yes I know their is a problem with the second one but the first one seems all right, but again ESR can't be guessed by just looking at the capacitors so I will check them...
                    No it has been soldered like that, I have already checked it. I think the manufacturer did that mistake, but the board is good enough as it’s giving a service of 4 + years .
                    I just found the marking weird, so I thought may be only I don't have seen something like this before, but now after all your replies I am sure its weird...
                    Anyway when I will replace them, I will check the values of the capacitors and confirm it on this thread.
                    Thank you all
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5069
                      • New Zealand
                      Not really weird, just uncommon I suppose. The markings isn't what's wrong with them, it's the bulging!
                      I can't see any brand or logo in your photos, do they have anything by the way?
                      -David VanHorn
                      • debjit625
                        • Jan 2012
                        • 14
                        No,they just have the value ,voltage and polarity marking...
                        And I didn't mean weird in that sence...yes more like uncommon.Even I think they are not commercial they are only available to the manufacturer.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          That's a 'no name' brand with a silver colored sleeve.
                          - Dr Seuss
                          • hectoroki
                            • Jan 2012
                            • 3
                            Maybe you can just check sizes.. and on a electronic dealer page.. just try to match something similar to the size and supposedly capacity?? .. well just my opinion..
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              If you can show some pics of the board and where the caps are we can guess what ESR grade they need to be.
                              [Probably nothing fantastic anyway given their size.]
                              580uF is a weird size. You won't find it in a 'good brand'.
                              I'd up it to the next standard size. [680uF]
                              Lacking more info....
                              In general FC, PW, KY, LXZ or similar is fine for the 220uF 16v.
                              The other one 'might' actually need to have decent ESR so I'd use an FM or FR just to be on the safe side.
                              Could probably recommend places to buy good caps but I dunno where in your solar system.
                              - Dr Seuss
                              • debjit625
                                • Jan 2012
                                • 14
                                Yes you are right but again the board is giving a very good service so may be thats the best stuff for it...at the VRM section they used 3300 mfd and 680 mfd...
                                Thanks anyway ,I know a lots of places to buy good caps.And I am from India,Kolkata
                                Many capacitors have identical value and packaging but differs a lot for example low ESR,of course I thought they should have some kind of different marking on them but after looking at the example caps above I am not sure anymore...
                                • kamalkhandal
                                  • Dec 2012
                                  • 1
                                  • India
                                  Hey Debojit,Did 680 worked for u and did u got 580 or replaced it with 680 too.please post as I am having same problem.
                                  • Rulycat
                                    • Apr 2010
                                    • 724
                                    • United Kingdom
                                    GSC/Evercon made silver caps like those.
                                    • RetroComputingGrotto
                                      Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                                      by RetroComputingGrotto
                                      I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                                      As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                                      What is your advice/opinion on whether or not on old(er)...
                                      04-03-2024, 08:30 AM
                                    • alfredo2j90
                                      Old electrolytic capacitors
                                      by alfredo2j90
                                      So as most of us know, old unused electrolytic capacitors are unrealiable due drying out and breakdown of the oxide layer.
                                      I have a few questions regarding these issues.
                                      1. Does using an electrolytic cap stop it from drying out or is it natural process that happens regardless?
                                      2. With the breakdown of the oxide layer the ESR will increase as well as DC leakage. Say the cap has remained unused on a motherboard, psu or games console for many years, if the cap does not physically pop when power is applied what other damage could occur to the system if it was...
                                      10-10-2021, 04:43 AM
                                    • P4C800
                                      ASUS P5A and P2B-S recapping. Searching old datasheets.
                                      by P4C800
                                      I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
                                      There are three mainboards:
                                      - ASUS P5A rev 1.04
                                      - ASUS P2B-S rev 1.03 "Rubycon"
                                      - ASUS P2B-S rev 1.03 "Chemi-Con"
                                      If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
                                      They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
                                      P5A
                                      10-09-2023, 05:55 AM
                                    • slybunda
                                      AA and AAA battery charger capacitors?
                                      by slybunda
                                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                      it has inside:
                                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                      2 x 470uf 16v LZ105c branded as G.Luxon
                                      not heard of these brands are they any good?
                                      iv attached photos of the charger and the board inside for an idea on the type of...
                                      12-24-2023, 04:41 AM
                                    • proxneo
                                      Recapping Sony ICF-SW55 - verifying cap values
                                      by proxneo
                                      Dear reader
                                      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                      At the moment, I have selected replacements based on the following list of values:
                                      3 x 470uF 10VDC
                                      3 x 4.7uF 35VDC
                                      4 x 47uF 50VDC
                                      8 x 22uF 6.3 VDC
                                      1 x 220uF 6.3VDC
                                      5 x 100uF 6.3VDC
                                      Which...
                                      06-21-2023, 12:38 AM
