Got a guy in with a comp, would poweroff after a while, took a look inside the PSU, two leaking YEC caps, one on 3.3v the other on 5v. So I replaced them with a pair of Sanyo MV-WX caps of the same rating, problem still the same...
Hooked up a multimeter to the 3.3v line, it's fluctuating wildly between 3.7-3.9v if I load the PSU a bit...
So I poked around the board a bit with the multimeter and found another cap connected to 3.3v, a Fuhjyyu, though it was not bulging... I desoldered it and took it apart, it was all moisty and gooey and nice with electrolyte, and the positive and negative leads where also connected nicley to it...
There are now two caps remaining on the secondary side, one 2200uF 16v Fuhjyyu for the 12v line and one 3300uF 10v cap for the 5v line, though both 5v and 12v are rock solid according to my multimeter so I've diagnosed those caps as fine (also seeing as the other Fuhjyyu cap seemed to be ok...)
So my question now is what could possibly be wrong? I tried powering up the PSU without the Fuhjyyu 3.3v cap and it behaved the same as before, no worse nor any better... It also behaves a bit strange when I flip it's powerswitch, (off) it pulses out current to the computer, making it flash it's standby power led...
I'd like to fix this PSU because I think the design is pretty good... It's rated for 235w and I'm pretty sure it can deliver that and then some more...
