Zener Diodes Always Fail Shorted. NOT.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    I found a simple self-oscillating class D amplifier schematic and built it on a stripboard. Despite the ugly layout it works (quite well i must add), and although i was expecting higher output before distortion for the given rail voltage, it seems like this topology "runs out of modulation" earlier than a clocked design, and certainly earlier than a class AB amp, and i can always use higher voltage rails when i design the final PSU. And things are certainly going to improve with a proper PCB anyway.
    I was adding a couple more bypass capacitors to the driver circuit and i shorted something, as i popped the fuse when i plugged the thing in. I replaced the fuse with a lightbulb and proceeded to troubleshoot the unit, i found the short and cleared it. However, after i did this i was getting about 2/3 the power output, and the output transistors would get hot. As they always sat at room temp before (that's the main point of class D isn't it), there was clearly something wrong.
    There are two back-to-back zeners that limit the voltage swing to the mosfet gates. On the top mosfet one of them was shorted. I replaced it, but the problem persisted. Upon additional testing, the other zener was found OPEN! After the second zener has been replaced the amp works fine again. And zeners are commonly used as overvoltage protection devices since they are "guaranteed" to die shorted. Wonder what would happen when your overvoltage protector fails open...
    A working TV? How boring!
  • CWB
    • Jan 2011
    • 34
    Re: Zener Diodes Always Fail Shorted. NOT.
    it is rare but it does happen , zeners can go into something other than the shorted mode .
    just like "regular" rectifiers ... i have seen them in both modes although the ratio is about 99:1 .
    bjts make things a little more interesting ... i have seen them with CE leakage but the BE and BC checked ok .
    • Krankshaft
      • Jan 2007
      • 2328
      I had a fuse go open resistance once on a cheap 5.1 audio amp with subwoofer the filament vaporized against the glass tube and the conductive metal acted as a bridge between the two metal contact caps. So the fuse actually became a resistor. I was getting a lower than normal voltage out of the transformer so the amp wasn't working but the power LED was dim.
      Of course the fuse was heatshrunk on a transformer secondary lead so I didn't check it till I ruled everything else out since I didn't want to take the time to cut it open. You usually think if you have power the fuse is ok.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        I can now safely say that i blew up this circuit in every way imaginable. I've shot the comparator now, and it happens that i don't have a spare. It'll have to wait until tomorrow. Well, at least i got to know it well enough to know what blows.
        Circuit is attached in case anyone wants to take a look.
        • Dvsr
          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
          by Dvsr
          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
          After replacing the caps I started testing out the speaker. It seemed...
          09-10-2025, 10:20 AM
        • caspian
          What Zener Diodes on a Linear Power Supply
          by caspian
          Dear members,
          I have a linear variable power supply with unknown brand name that I used for voltage injection.
          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
          In addition, I discovered that its zener diodes are defective.
          I can replace the burned transistors.
          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
          Therefore, I cannot replace the zener diodes.
          I do not want to test the zener diodes in a test circuit to discover their model or value.
          no schematics are available...
          05-26-2025, 12:38 PM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          The TV does not turn on, the standby indicator is on. All voltages are present.
          Emms is dead. Not readable, not detected.
          Replaced emmc.
          But with another dump there is no launch
          Terminal log
          UART
          AC_ON
          RPMB key is not yet programmed
          HASH1_VERSION=0x00000000 64bit
          E-B
          FDE enabled
          layout pattern onebin by SAR7,0...
          06-01-2025, 02:11 AM
        • DjKrish
          Zener diodes component equivalents
          by DjKrish
          Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
          1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
          2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
          3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
          These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
          08-15-2021, 11:06 PM
        • reessi
          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
          by reessi
          Hello:
          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
          I started on the ACER:
          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
          10-29-2024, 11:31 AM
