I am trying to repair a acer laptop with a dark panel. The panel first came as completely dark. I first suspect the inverter. Ordered one online and replaced it.
It lights up for about 5 minutes thru the windows boot screen. Then shuts off again. The inverter replacement improves the problem but doesn't fix it.
I tried to turn down the brightness a bit, the light starts to flicker then shuts off as well.
Should I try a different inverter? or should I try to replace the bulb, which is something I have little confidence in doing (and probably give up at that point)?
Another laptop in the past, I was able to keep the light up by lowering the brightness. I cannot do the same with this one. Is there any difference between the 2 cases?
