Hp 22-DD0302IN aio strange issues
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    MODEL:HP ALL IN ONE 22-DD0302IN
    Problem:
    hp bios update failed unable to open bios image file
    This message pops up and it reboots in a loop. I've flashed 086F3 bios from HP site and replaced eeprom chip as well.(Replacement is also 1.8V chip). After flashing, still get the same pop up error msg.
    I thought it may be bios image update is stored in SSD(Kingston 250),so i replaced the ssd with samsung 512 nvme.
    The mb doesnt show anything on screen when any other SSD is installed(I tried several brands,capacities) even though its new. Went ahead and removed SSD and inserted win11 bootable only with no hdd/ssd.Still no image on screen.The moment you put its original kingston 250 back,there is display on screen with error popup.
    Whats the way out? I tried my level best but couldnt understand the puzzle.Could it be EC firmware?
    PS: MB posts correctly with other SSD as well(usb kbd numlock light works with no image on screen.)
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Hp 22-DD0302IN aio strange issues
    Bootblock likely looking for a recovery image on the SSD. I would try flashing a dump from another machine rather than the update file from the website, it could be incomplete.
    A working TV? How boring!
      • 20933
      Are you the first tech to work on the PC or has the bios been flashed before. If you`re the first you must have looked at the BID and found 086F3 ,you would expect it to be the correct version.If you`re not the first or you suspect microsoft update has somehow flashed the wrong one then there are 5 more bios to choose from.Its the same number of bios options whether you enter the model number 22-DD0302IN (it gives another option to choose product 681U0PA, if that isn`t the product you should search for updates by series instead - https://www.badcaps.net/forum/showthread.php?t=122195) or if you choose by series 22-DD0000i .
      Edit: Forget all that,the other 5 are all intel bios.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        The hp website has complete 16MB bios,so that cant be the issue.
        Yes I'm the first tech to open up the PC. i've read the bios and its BID is 086F3 for sure.
        What is puzzling me is that there is display on screen only with KINGSTON 250 SSD(which came with this PC) and no display if you put any other SSD.
        I dont think its main bios issue since i've access to another bios read from same PC and flashing that bios also gave same symptoms. thats why i didnt posted it in the bios forum.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Finally was able to solve the mystery. Opened the backup read from original bios in hex editor. zerro filled entry from hex D000-DC6F which were all entries showing bios upgrade failed. Saved this bios and re flashed on the PC-still same error boot loop. tried usb recovery this time it worked and flashed bios successfully after several reboots. earlier when usb recovery was tried(the same pen drive was used earlier with exact same contents),it didnt gave any beep sound and nothing went correct but this time it worked. Not very convinced myself, but anyway case solved. It seems in such bios flash failure,usb recovery only works any flashing the bios chip externally perhaps dont work.Thanks everyone who responded
          PS: Now any brand nvme ssd works on this PC.
          • ronelex
            • Oct 2016
            • 195
            • Philippines
            Hellow sir, can you share the bios you use? is it for ryzen processor? I also have this problem https://www.badcaps.net/forum/showthread.php?t=123248
            • ronelex
              • Oct 2016
              • 195
              • Philippines
              Problem solved, reflash bios by the one I got on the BIOS update install on my USB,
                • 20933
                I`m happy you got it fixed,and thanks for the info you gave me via PM.
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • iZakre
                  HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                  by iZakre
                  Hello everybody!
                  To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                  The thing is that I had installed TeamViewer and could log into the computer...
                  02-19-2023, 02:27 PM
                • Loli Popu
                  DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                  by Loli Popu
                  Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                  12-13-2024, 03:28 AM
                • al3m0di
                  Update bios EFCN58WW to EFCN59WW
                  by al3m0di
                  Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                  I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                  The BIOS version is EFCN58WW.
                  When I turn on the device, it displays the message:
                  "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                  The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                  I've tried
                  07-29-2024, 10:32 AM
                • Focus2005
                  HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                  by Focus2005
                  Hello everyone.
                  I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                  05-01-2025, 05:41 AM
