HP AIO 23- G111nl - Unable to restore bios by usb drive
  • tyl85
    • Nov 2020
    • 51
    • Italia
    Hi, i have this 23'' AIO similar to a big notebook
    Black screen no backlight
    POWER LED:ON HDD led blnks very rapid
    First question:
    4 internal jumper, how to use?
    1) CLR_PW
    2) BOOT BLOCK
    3) BOOT WRITE
    4) FDO
    Second question when i attemp to flash bios by usb drive jumpering BOOT_BLOCK
    i hear 8 long beeps then usb drive flashing, then hdd light blinks rapidly e i got screen on HP "unable to open bios image file" then goes off
    what i can do?
    tried 2 different usb drives
    2 bios file from website
    thanks in advance
    • 21841
    Re: HP AIO 23- G111nl - Unable to restore bios by usb drive
    Before you start messing around flashing the bios reseat the LVDS screen cables.If the gold pins are tarnished clean them with a pencil eraser.Remove the RAM as well,and clean the pins also try known good working RAM.
    If you are going to flash the bios you must choose the correct one ,there are 5 different ones listed at HP support , ROM Family SSID 2B06/2B08/2B13/2B0D/2B21.
    Jumper 4) FDO should unlock the flash descriptor,you can`t flash the full bios without this unlocked.
    2) BOOT BLOCK and 3) BOOT WRITE should also be jumpered.
    Flash the wrong bios and it`ll be bricked.If you have an SPI programmer i highly recommend that you make a backup of the bios first,and post it here.
    • tyl85
      • Nov 2020
      • 51
      • Italia
      tried to clean/change ram
      lcd works
      the bios file was from official hp website and i've selected 23-g111nl,
      now i tried FDO jumpered also
      thanks for the reply
      i have ch341 programmer also
      • Vesko356
        by Vesko356
        08-11-2023, 03:27 AM
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
      • i19
        Asus UX3402 / Q409Z - No sound, no TPM, Boot issues: Bios flash?
        by i19
        Hi
        I got an Asus UX3402 / Q409Z and after a BSOD I lost sound, tpm 2.0, and if it turns off it can take HOURS before I can boot again.
        Reading here and on reddit I figured its a BIOS issue, and that reflashing it may fix the problem.
        I want to use an CH341A (new model with 3.3v) to flash it.
        My problem is that I'm not sure if the SOIC8/SOP8 clips will attach to the chip and hold properly? (haven't opened my laptop yet, I'm basing this assumption on a picture from the same thread I attached).
        Any tips on how to connect to it? Maybe something...
        08-20-2024, 06:50 AM
      • James Jackson
        Panasonic CF-20G0247VM BIOS Bad Flash Help
        by James Jackson
        I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
        Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
        05-01-2025, 11:28 AM
      • spmetroil
        Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
        by spmetroil
        I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
        The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
        I have a CH341A programmer and I already attempted the following steps:
        1. Identified the correct chip (W25Q128, 3.3V SPI flash).
        2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
        3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
        08-19-2025, 09:23 AM
