Found this 2~24 Series Lithium Battery Equalizer device,is it worth the money or not
    • Jul 2011
    • 6070
    2~24 Series Lithium Battery Equalizer For Lipo/Lifepo4/LTO Measurement, Maintenance, Overhaul, Differential Pressure Repair
    https://www.aliexpress.us/item/32568...US%21738379857
    Last edited by SMDFlea; 06-28-2023, 08:43 AM. Reason: Renamed thread title to make it more relevent.
    • 31265
    Re: I found this device and I am wondering if it is worth the money or not
    unless you work in a powertool service-center or rental place, it's too expensive to justify
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8344
      Too steep for my pocket book TBH.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8704
        I think I've been duped again...
          • Jul 2011
          • 6070
          Re: Found this 2~24 Series Lithium Battery Equalizer device,is it worth the money or
          I might get one but I am going to try to find a cheaper one than this one
          What I impressed with is that it has a voltage reading on each battery cell which is a plus when you are testing BMS balancing protection boards
          I found an alternative battery meter for BMS balancing protection board testing
          1S-24S Lithium Battery Pack Single Cell Voltage Tester for Lifepo4 Li-Ion LTO
          https://www.ebay.com/itm/23492891374...3ABFBMtPrFj6Ni
          I will also be buying the adapter board as well I will just have to build a testing jig for this setup
            • Jul 2011
            • 6070
            Finally arrived today in the mail I powered it up just to make sure that powers ON and that the device was not damaged in any way
            Here are the results from the battery packs that are for the battery operated air compressor
            This will do exactly what I want it to do I just have to make the testing jig so I can hook up the the SkyRc battery charger to it and or a BMS balancing protection board to see how well it behaves in the balancing mode
            The left side of this display has some very interesting data that can be very informative about the battery pack
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8344
              Well… that’s more like it! The pricing is much better too and it comes with a display! Cool!
                • Jul 2011
                • 6070
                Well… that's more like it! The pricing is much better too and it comes with a display! Cool!
                How do I determine what type of JST pitch and spacing this connector configuration this that is used on this BMS balancing protection board
                What I do know is that it is 24 pin JST type connector
                Because I want to modify the connector so that I can put this single cell voltage in series with the BMS
                I could buy two 12 pin BMS balancing protection boards for the JST connector but I really do not have a use for 12 pin BMS protection boards right now
                  • 31265
                  use a caliper to work out the pin spacing
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8344
                    I do it same way as stj. I’ve got the pins and work out the size and spacing using a calliper.
                      • Jul 2011
                      • 6070
                      I do it same way as stj. I've got the pins and work out the size and spacing using a calliper.
                      I looked at Digikey website last night for JST connectors and found some but there are several different types so I am not sure which style it is
                        • 31265
                        pictures?
                          • Jul 2011
                          • 6070
                          Well I found the active battery balancing board that I going to use with the device that I bought earlier
                          https://www.ebay.com/itm/38554037757...Bk9SR7SbkJG-Yg
                          Going to buy the 24 cell version and a 2 , 3 , 4 , 5 , and a 10 cell version because I am using these battery cell counts right now
                            • Jul 2011
                            • 6070
                            Originally posted by stj
                            pictures?
                            There is a picture of the connector on the website link and the picture below
                            JST XH Pitch 2.54mm
                            As you can see in picture below this battery pack is not very balanced this is why I need a balancing board for battery packs that I going to use my own charging device
                            • redwire
                              • Dec 2010
                              • 3912
                              The board uses ETA3000S2G Inductive Cell Balancer IC. SOT23-6 marking GIYW.
                              Not a bank of 1R0 resistors lol.
                              It seems to take energy from a higher voltage cell and transfer to a lower voltage cell. Should make much less heat and waste less energy I suppose.
                                • Jul 2011
                                • 6070
                                I will find out in a month or so because it might not be until next week before I will order the items that I mentioned above
                                When I get this device I will write a review about it and how this system will be setup and configured stay tuned for updates when they come available
                                  • Jul 2011
                                  • 6070
                                  I bought a couple more of these boards and going to modify them so that I have the wires as the output side not the input side
                                  https://www.ebay.com/itm/165951907943?var=465451357281
                                    • Jul 2011
                                    • 6070
                                    Well did have some time this early morning to make up some connectors “see the description” as you can see in the picture below
                                    “DIY Toy JST XH Pitch 2.54mm 2~12P Connector 100/200/300mm 26AWG Cable Wire”
                                    I also ordered the same type except that they are 2.00 pitch not the 2.54 because I both types of connectors for some BMS protection boards that I have and I want used them and watch them charge and discharge when testing them
                                    I have to work on the charging system for this testing station but I have to wait until I have all of the cables and connectors made up then I can concentrate on the charging stations going to try to include the broken battery testing machine that the charging/discharging circuit does not work properly and has been removed for the enclosure
                                      • Jul 2011
                                      • 6070
                                      Well I found a stand for my battery BMS voltage monitoring board in the one picture you will see a
                                      ( red circle around the )
                                      tablet holder that is suppose to on this stand but instead of doing that I put the battery voltage monitor on it instead I used two fender washers and two rubber washers and sandwiched the plexiglass in between the washers
                                      Now I need to spend some time working on the switching power supply and it hookups to the battery voltage monitoring board
                                      If anyone is interested in the tablet stand please let me know and I will post a website link on EBay to where you can get one
                                      One note not all tablet stands are the same and some of them do not have it where you can take off or just not use the tablet holder itself and just use the stand
                                        • Jul 2011
                                        • 6070
                                        I finally did receive the correct JST PH2.00 pitch cable female ones that is only ones available from this eBay seller and also only offered the male circuit board connector
                                        I did place a second order a few days later from the same seller that still has some pin versions available and all that the seller had left
                                        Now I have to battery monitor/BMS connectors for the 2.00 pitch that are on battery pack
                                          ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:28 PM
                                          ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                                          This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
