Found this 2~24 Series Lithium Battery Equalizer device,is it worth the money or not
    • Jul 2011
    • 6039
    Re: Found this 2~24 Series Lithium Battery Equalizer device,is it worth the money or
    Dose anyone know where I can find some good quality alligator clips for my test leads that are medium size not the very small or the very large ones I used to get them from Radio Shack back when they were around
    I found some at MPJA but they are little too small for what I am looking for Home Depot and Lowe’s have some but they are either too small or too big
    I forgot where I had bought some that are the right size but the quality of them are crap because they bend right near the stiff wire to keep them closed
    If can find some of the size that I am looking for I posted the picture of them
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Hazard Fraught Tools alligator clips insulation boots are horrible ...
        • Jul 2011
        • 6039
        Yes I know I have tried them before and not only that the wire that used is also looking like it is poor quality as well
        But the question is where can I find some good quality ones that I do not have pay an arm and a leg for them
        • diif
          • Feb 2014
          • 6978
          • England
          This sort of stuff comes from Aliexpress, what size jaw opening do you want and what's the maximum current they need to handle ?
            • Jul 2011
            • 6039
            Update on the 2.00 pitch connectors
            I used some connectors of a incomplete BMS protection board that I could not reuse so I reusing some of the components of the board for the same purpose but in a different configuration
            Using these two connectors I loose numbers 12 and 13 when using these connectors not bad I could put a wire in the empty connector and then I would have all of meter connection which I might do later if needed for a battery pack but right now I can except the fact I loose two meter readings
              • Jul 2011
              • 6039
              I ended up putting a two pin connector on the bottom of the and removed one of the wires so I would not short circuit the battery cell by accident
                • Jul 2011
                • 6039
                I just finished putting new wires in the one of the two connector ( in post #25 is a picture of the board that I am taking about ) that was for the BMS protection board of a 36 volt battery pack that I modified the battery pack that I wrote up a post a few months ago I will be taking this battery pack apart again to add this meter module for multi battery cells so when I put the battery pack on charge I can see what all battery cell rails are doing in real time
                Now I have to remember where I put the other two female connectors that I have so I can make up the other side male connector
                This project is a work in progress and as I have time to devote to it I still have to make up cables for other battery cell configuration which is going to take some time to complete
                I have both versions of these connectors to do for both boards the 2.00 mm and the 2.00 mm pitch connectors
                  • Jul 2011
                  • 6039
                  Well I found the container that had the BMS board in it and I also found the container that that had the female connector ( unfortunately there is one connector that has not been found yet) in it so I was able to complete the individual battery cell connector so now I have to put the battery holders on a cutting board so they will stay in place it is also going to be used as testing jig for selecting and matching battery cells together while they are changing and discharging cycle curves
                  In the picture you can see that the connector on the right side has a white wire and a yellow wire on the other end of the connector these two wires are not being used when testing individual battery cells
                  The white wire is to let me know not use it in individual battery cells function and the same thing with the yellow wire
                  Now when testing a 24 battery cell function then I would use all 25 wires instead of 23 wires in the single battery cell battery testing mode
                    • Jul 2011
                    • 6039
                    An update on the types of battery cell-s voltage monitoring devices there is a version that has both 2.00 and 2.54 pitch connectors on the same board
                    Here is the seller that I bought two of them from
                    https://www.ebay.com/itm/166098248178
                    The reason I bought the other version was that I going to remove the 2.00mm and the 2.54mm pitch connectors from the transfer board and put it on this board but modify the connector so that I have one continuous connector
                    I going to use the transfer board as jig boards so I can easily make and remove connections
                    As shown in an earlier post where I mentioned that I put the battery cell monitoring module on a stand I am going to do the same thing with this power supply but I going to have the meter module ii a different location so that it is easier to read and will probably mounted on a cutting board so that the power supply and the battery cell monitoring modules are kept together and easier to use and kept organized
                    I found a external meter module enclosure that this power supply meter module fits I just have to extend the three wires for the meter function and the two other wires for the power to the meter module
                    One note about the power supply meter module has been modified so that it functions correctly for this power supply and I did not want try to figure out exactly what changed in order for it to work correctly for this power supply if this meter module goes bad I have some meter modules that are the same basic design as the original meter module that is used in this power supply
                      ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 03:28 PM
                      ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
