How to fix not being able to enter the bios on Lenovo Ideapad 110-15ACL?
  • chris89
    • Jan 2015
    • 69
    • United states
    I've been trying everything from every possible way to enter the bios, and it won't let me. So I reset the cmos battery, which didn't work.
    I tried SCT Winflash and winflash32.exe at the command prompt and i even went into Ubuntu 21.04 to try to do it but got too many errors, to no avail.
    I was wondering if someone here is genius enough to help me determine the filename needed for crisis usb bios recovery because everything i tried hasn't worked.
    I appreciate it.
  • peste
    • Dec 2016
    • 13217
    • ROMANIA
    Re: How to fix not being able to enter the bios on Lenovo Ideapad 110-15ACL?
    I appreciate it.
    you have what you need at post #2..
    https://www.badcaps.net/forum/showth...ight=110-15ACL
    • chris89
      • Jan 2015
      • 69
      • United states
      Thanks but im not sure what i should do with the file sir?
      Thanks again
      • peste
        • Dec 2016
        • 13217
        • ROMANIA
        Thanks again
        to write it on the bios chip..
        https://www.youtube.com/watch?v=DWWigscuQDY
        • chris89
          • Jan 2015
          • 69
          • United states
          My laptop works fine just cannot enter the bios setup. If u can define my recovery filename id appreciate it. Ill talk more about it later. Thanks
          • peste
            • Dec 2016
            • 13217
            • ROMANIA
            do you need the bios or not...you can enter the bios or not, you can change it in the bios or not...be more specific because I didn't understand anything..
            • chris89
              • Jan 2015
              • 69
              • United states
              Well I have the BIOS file, unless there's a better one out there? 1qcn32ww, just need to know if my flash drive being a 16gb sandisk isn't compatible with bios recovery or if im doing something wrong? Thanks
              PS - to answer your question. I cannot enter the bios at all with any approach.
              Also will the BIOS you suggested have extra advanced options in the BIOS or can u mod the bios for me so when i do recover it will have the advanced options unlocked?
              Thank u so much kind sir
              Lenovo ideapad 110-15acl winflash32 warning rollback flash is disabled in BIOS
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Page 8 of User Guide here:
                https://download.lenovo.com/consumer...Info:UserGuide
                refers to Novo button to start BIOS setup utility
                • chris89
                  • Jan 2015
                  • 69
                  • United states
                  I just wanted everyone to know the novo button works, it displays the screen menu to enter the bios and i press enter selecting bios setup utility and it simply flashes a black screen and reboots and continues to windows. It does this same thing with every possible method to enter the bios wither it be fn f2 or f2 alone or f1 which its f2 im certain of it but still nothing and windows 11 recovery menu reboot to uefi menu doesn't work either. No way may i enter the bios on my laptop, Lenovo Ideapad 110-15ACL 80TJ without Radeon R5 M430 gfx chip but with A6 7310 APU.
                  If I could find a modded winflash32 or winflash64 utility to use with dos commands in windows that allows to bypass checking current bios then id be in business.
                    • 21492
                    https://www.bios-mods.com/forum/Thre...apad-110-15ACL
                    • simplepunk14@gmail.com
                      • Apr 2023
                      • 1
                      • Philippines
                      sir chris i have same issue with you same model of lenovo ideapad 110 15acl cant open bios did you fix this problem ? thaks
                      • chris89
                        • Jan 2015
                        • 69
                        • United states
                        I used my sandisk cruzer glide 32gb and formatted fat32 and threw the BIOS.cap file on there and another of the same file named 1QCrisis.bin as I wasn't sure which file it was looking for as there is no documentation on the net of this specific laptop doing the BIOS RECOVERY.
                        Just throw the bios.cap on there and put it in the black usb 2.0 port, the usb flash drive. Turn off the laptop with it plugged in with a full battery and hold FN + R until it starts the recovery procedure. It fixed it for me.
                        • xi8000
                          • Oct 2023
                          • 1
                          i do have the same problem: cannot enter the bios on my ideapad 110-15ACL.
                          I tried successfully the bios update like you, chris, explained. but after this, i'm still not able to enter the bios.
                          can anyone send me a bios which is enterable?
                          my exact ideapad is the following:
                          Lenovo ideapa 110-15ACL
                          MTM80TJ00EUGE
                          • peste
                            • Dec 2016
                            • 13217
                            • ROMANIA
                            MTM80TJ00EUGE
                            read this..
                            • chris89
                              • Jan 2015
                              • 69
                              • United states
                              https://extremehw.net/topic/2649-len...eboots-advice/
                              • Laller
                                • Dec 2023
                                • 3
                                • Hungary
                                Thank you! It works again with this method!
                                • jendkkd jeje
                                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                  by jendkkd jeje
                                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                  10-11-2024, 03:12 PM
                                • joven016
                                  Lenovo Ideapad S145 need working bios HELP!!
                                  by joven016
                                  Problem is blinking power led only
                                  i don't know exactly if it's s145-15igm or s145-14igm
                                  have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
                                  Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
                                  Already tested some of posted bios here
                                  S145-14igm - success but invalid serial and not booting on OS
                                  S145-15igm - success with serial and some other info in bios but still not booting on OS
                                  already tried installing new windows but always booting on bios setup
                                  windows installer flash drive detected on...
                                  08-21-2025, 10:55 PM
                                • lucaszmn
                                  Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                                  by lucaszmn
                                  Problem:
                                  I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                                  Initial Findings:
                                  • My current BIOS version is N1KET58W (1.45).
                                  • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                                  • I have the ability to use command-line tools on a Linux machine.
                                  Troubleshooting Steps & Conclusions:
                                  • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                                  • I concluded that the
                                  08-12-2025, 03:01 PM
                                • Wahaz
                                  by Wahaz
                                  10-30-2023, 08:42 PM
                                • Popel1083
                                  Lenovo IdeaPad U330p Read Bios than Bios Password Remove
                                  by Popel1083
                                  I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
                                  SN: QB08570065
                                  MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
                                  08-06-2024, 05:52 PM
