Dell Inspron 3593 LA-J091P HDD Check Error
  • sirzat
    • Jun 2015
    • 30
    • Tekirdag
    Hello.
    Existing BIOS file sometimes gives disk error. (m2 and SSD)
    Can anyone help with cleaning the bios?
    Services Tag : 9ZLW943
    Thank you for your help
  • hoaca388
    Badcaps
    • Jan 2022
    • 12421
    Re: Dell Inspron 3593 LA-J091P HDD Check Error
    Originally posted by sirzat
    Hello.
    Inspiron 3593
    Service Tag: 9ZLW943
    • sirzat
      • Jun 2015
      • 30
      • Tekirdag
      Originally posted by hoaca388
      Inspiron 3593
      Thank you for your interest.
      But the BIOS you prepared did not work.
      It opens once but no display.
        • 22135
        Sometimes you have to wait around 15 minutes.It should reboot itself a few times.
        • sirzat
          • Jun 2015
          • 30
          • Tekirdag
          I tried again on your suggestion.
          I think there was an error in the first operation.
          Because when I typed it again, the device worked.
          thank you for your attention
          • dreico33
            TL866 II Plus Check ID Error on various IC
            by dreico33
            Hellow guys , i really need your help here.
            Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
            11-04-2024, 03:13 PM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            The TV does not turn on, the standby indicator is on. All voltages are present.
            Emms is dead. Not readable, not detected.
            Replaced emmc.
            But with another dump there is no launch
            Terminal log
            UART
            AC_ON
            RPMB key is not yet programmed
            HASH1_VERSION=0x00000000 64bit
            E-B
            FDE enabled
            layout pattern onebin by SAR7,0...
            06-01-2025, 02:11 AM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • ianbak
            Dell Vostro 3578 Battery Error
            by ianbak
            Please can anyone shed some light on why my Dell Vostro 3578 is giving the following BIOS error: 'The primary battery is not identifiable and this system will not charge this battery pack.'?
            The problem is not the battery - I've tried three different identical ones, all Dell OEM. They all work perfectly in other systems (different models, though) whilst giving the same error in the Vostro.
            The laptop will run happily from the battery if it is charged and Windows accurately reports the charge level, proving that the communication between the laptop and the battery...
            10-17-2025, 02:52 AM
          • vickey_vip
            dell OptiPlex 3050 all in one bios error solution
            by vickey_vip
            Hi I need bios for dell OptiPlex 3050 all in one mb part is ipkbl-sr/35w.
            Old bios display is coming but giving following error
            (A7) FW downgrade - request mespilock fail upon starting
            After this error all in one again restart and again same error not booting
            I am attaching here old file
            Urgent help required because its server pc of someone
            Link of dell page here
            https://www.dell.com/support/home/en...SQT090/drivers...
            02-23-2024, 11:49 PM
