BQ24735 - faulty?
  • Jane
    • Aug 2010
    • 188
    BQ24735 - faulty?
    Can you please give your opinion on this matter?
    Laptop does not work. I checked voltages of charging circuit BQ24735 .
    Values are :
    pin 20: VCC 19V
    pin 6: ACDET > 2.4V
    pin 16: REGN 6V
    pin 5: ACOK 2.62V
    Are these values correct and (if BQ24735 is working in the correct way)
    ACDRV (pin 4) should have more than 19V?
    Or I must check any other values to be sure to decide that BQ24735 is faulty?
    AS I have ACDRV about zero, so I guess BQ24735 is faulty.
    Your opinion?
  • mon2
    • Dec 2019
    • 14618
    Re: BQ24735 - faulty?
    It looks good so far.
    The boost voltage of ACDRV is based on CMSRC pin and REGN.
    You should have a series resistor on ACDRV of ~4k (based on the TI schematics which everyone appears to follow as a ref design).
    Remove this series resistor for a quick test and power up again.
    What is the voltage of ACDRV at the IC side of this signal (without the resistor that is driving the gate of the 2 x DCin mosfets) ?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      to me ACOK at 2.62V is not correct. Should be 3.3V. Without a valid value of acok,acdrv wont work.
      • Jane
        • Aug 2010
        • 188
        ACOK, should be HIGH, not LOW but what voltage here means HIGH?
        HIGH is 3.3V and higher? Or even 2.6V higher?
        • mon2
          • Dec 2019
          • 14618
          ACOK is a power good pin and will be open drain.
          That is, the pin will be LOW (~0 volts) or open like a SPST switch (high impedance / floating). Therefore, this pin will contain an external pull-up resistor to a voltage selected by the designer.
          Sometimes, the pull-up voltage is REGN but not always.
          Since ACOK is NOT a logic low (~0 volts), this means ACOK is floating. The actual pull-up voltage is defined by another power rail.
          See attached datasheet for more details of ACOK.
          • Jane
            • Aug 2010
            • 188
            @mon2
            Thank you for your explanation.
            I checked the BQ24735 datasheet and I can see that ACOK is connected through resistor R5 (10k) to 3.3V.
            But in my laptop schematic Acer Swift SF314-51 it is connected via R8811
            1KOhm only.
            So, do you think ACOK at 2.62V is not correct - it is low , as mcplslg123 says above?
            Or is it OK?
            • mon2
              • Dec 2019
              • 14618
              1) post or link the schematic of your logic board so we can all review
              2) on cmos logic levels:
              The logic level thresholds for 3.3V CMOS are a known standard. For a 3.3V CMOS device to acknowledge a logic high or low, the required voltages are as follows:
              Logic low - input must be between 0V and 0.8V.
              Logic high - input must be between 2V and 3.3V.
              3) since the ACOK pin is not ~0 volts, this charger IC is ok with the adapter detection based on the voltage present at the ACDET pin.
              4) what is the voltage shown in the schematic for the pull-up rail on this 1k at R8811 ?
              If the rail is ~3v then yes, agree that this voltage is lower than it should be.
              Measure the voltage present on the other side of the pull-up 1k resistor. Post the measurement.
              5) next, remove this resistor with care (flux, low air pressure, enough heat to melt the solder). Do not lose the part but the resistor value is not critical. Could be almost any value from 1k..10k, as an example.
              After this resistor is removed, is the pull-up voltage different? If it is not different, then ACOK pin is not influencing the voltage on this pin. That is, the voltage value is low due to another factor on the logic board.
              6) remove all power, meter in resistance mode. Check the resistance to ground of the pull-up voltage rail. If the resistance is low, then there is some fault on this line. It is not the ACOK pin since the pull-up resistor has been removed for testing.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                I highlighted the acok voltage as there could be a potential problem If the pullup voltage of acok resistor is 3.3V.@mon2 has already advised on how to proceed.On many occassion i found this resistor to be bad pulling acok comparitively low. So it needs to be ruled out.
                • Jane
                  • Aug 2010
                  • 188
                  Thank you for your emails
                  @mon2
                  Please find enclosed the schematic of the laptop I try to repair
                  (BQ24735 is on page 86)
                  I removed resistor R8802( 4.02k) going from ACDRV to Mosfet but voltage was still not changed ( about 0V)
                  Removing R8811( about 1k - going from ACOK) partly helped.
                  Now ACOK is 3.3V but ACDRV is still about 0v
                  So, can I suspect BQ24735 being faulty?
                  P.S.
                  I also find out that Q8800 was shorted so i removed it - not replaced yet
                  Thanks for help
                  • mon2
                    • Dec 2019
                    • 14618
                    Yes, now replace the charger IC.
                    Still, leave the 4k resistor in series with ACDRV off the logic board. Test again to confirm that ACDRV is ~25v when powered on.
                    Be sure the dcin mosfets that is driven by the 4k resistor are not defective. Remove all power, meter in resistance mode, check the resistance across the mosfet pins.
                    Then solder back the 4k resistor and test again.
                    • Jane
                      • Aug 2010
                      • 188
                      Acer SF314-51 - BQ24735 problem
                      This is part 2 of this thread
                      https://www.badcaps.net/forum/showthread.php?t=111377
                      To sum it up:
                      Acer SF314-51 is dead. I found out that ACDRV pin of BQ24735 is zero
                      while some of other values are correct - see the given thread above - so I replaced the BQ24735..
                      But the problem remained. Finally I found out there is a short between
                      pin 1( ACN) and pin2( ACP) of BQ24735.
                      I tried to find the culprit but no success.
                      Is it possible to inject a voltage to the rail and check with thermal camera?
                      If so, what voltage/current to use so that it can be possible to see the short in the camera?
                      Or which parts to check?
                      (I checked C8814,C8806,C8805,Q8801,Q8802 and probably C8828,C8813 too - not have boardview- and also BQ24735)
                      I enclosed complete schematic and also only a page of the charger.
                      Thank you for your hint/help
                      • Sephir0th
                        • Oct 2020
                        • 1283
                        Re: Acer SF314-51 - BQ24735 problem
                        This "short" is normal. There is nothing more than the Current sense resistor between these rails which has almost no value itself. You'll notice the same design at the sense resistor of the charging rail. So the issue is elsewhere. REGN is still present?
                        FairRepair on YouTube
                        • mon2
                          • Dec 2019
                          • 14618
                          As per above comments - the current sense loop will appear to be a short but it is not. Pins 1 & 2 are connected by a very low resistance current sense resistor so it appears like a 'short'.
                          It is important to review the replaced charger IC for possible other faults / soldering.
                          Remove the ACDRV 4k resistor and power up again.
                          Confirm the voltage of:
                          REGN (pin #16) ; must be 6 volts
                          ACDRV (pin #4) ; should be DCin adapter + 6 volts (REGN)
                          ACOK (pin #5) ; should be a logic '1' to denote the adapter in is OK
                          • Jane
                            • Aug 2010
                            • 188
                            Thank you for the replies.
                            I am sorry I did not describe my problem clearly. There is a short between
                            pin 1( ACN) and Ground and pin2( ACP) and Ground of BQ24735.
                            (I did not mean short between ACN and ACP.)
                            Yes, there is very low resistance between pin 1( ACN) and pin2( ACP)
                            but my problem seems the short circuit to Ground .
                            Yes, above values are correct. (but to have ACOK logic '1' I have to remove
                            1k resistor from that ACOK.If not removed, ACOK voltage is about 1.4V
                            I also removed ACDRV 4k resistor but no proper output still.
                            But I think the main problem is the short to Ground between ACN ( ACP).
                            What do you think?
                            Thank you for help
                            • mon2
                              • Dec 2019
                              • 14618
                              Apply lots of flux and then hot air with enough air pressure to melt the solder under this charger IC.
                              Spin the hot air tool in circles on the top of the IC.
                              The ic will sink in the liquid solder on its own.
                              Then gently nudge the IC to shift the part. The part will shift but return to proper alignment on its own. This is needed to remove any shorts.
                              Very likely the ic is shorting from the soldering process.
                              Then measure for the short again. Repeat if needed till the short condition is removed.
                              • Jane
                                • Aug 2010
                                • 188
                                But I removed that charging IC as well (and tested for short) and there was still a short circuit - between Ground and ACN and between Ground to ACP.
                                Is it possible to use thermal camera? But what current/voltage to use?
                                Thank you for reply
                                • mon2
                                  • Dec 2019
                                  • 14618
                                  Is JP8805 a solder blob on the board?
                                  If yes, remove it and check if the short is still present or not.
                                  There are only a few parts linked to the ACN pin. One of them may be causing the short. Review the caps on this line.
                                  • Jane
                                    • Aug 2010
                                    • 188
                                    I removed JP8804 ( JP8805 is connected in PCB itself). Now there is no short on C8814 and on C8806( pin 1 on the schematic). So, I think BQ24735 should be OK. Do you agree?
                                    I tried to find out R8808 but I did not.(no boardview ). Now there is not a short circuit on drain Q8801( there was when there was JP8804 connected).
                                    Short circuit remains on C8805, C8806( pin2) Q8802 drain, C8828 and C8813.
                                    I measured Q8802 and also cappacitors and they were not shorted.
                                    Do you have any hint, please?
                                    • mon2
                                      • Dec 2019
                                      • 14618
                                      You are getting closer but we still cannot rule out this charger IC.
                                      Next (in order):
                                      1) remove the solder blob @ JP8805. Check the resistance to ground again.
                                      If you do NOT see a short on C8805 after this removal, then the charger IC is NOT the fault.
                                      2) After the above, review the caps near Q8804. You may have a shorted cap there.
                                      3) Do you have a lab adjustable power supply ? I think you can locate the bad part without one but a variable power supply will help.
                                      • Sephir0th
                                        • Oct 2020
                                        • 1283
                                        Haha, I have re-read the thread just to be sure and we indeed missed a simple short to GND of the main power rail...
                                        As described above I wouldn't waste more time with this and start injecting if a high side short can be ruled out before. So what is the exact resistance to GND at the current sense resistor with decimal place?
                                        • estebanpe
                                          asus x541sa no power (bq24735) no ACDRV
                                          by estebanpe
                                          Hello, I have this board that drives me crazy, I can't activate the input mosfets, I have changed the bq24735 with the same result
                                          These are the IC voltages and I also leave a couple of voltages extra
                                          1 3.9v
                                          2 3.9v
                                          3 0v
                                          4 0.03v
                                          5 0.05v
                                          6 2.6v
                                          7 0.004v
                                          8 0.020v
                                          9 0.020v
                                          10 0.15v
                                          11 3.13v
                                          12 3.10v
                                          13 3.11vv
                                          14 0v
                                          15 0v
                                          16 6v
                                          17 5.8v
                                          18 3.10v
                                          19 3.10v
                                          20 19v
                                          P_CHG_AC_GATE_20 0.010v
                                          AC_BAT_SYS 3.4v​
                                          10-15-2024, 05:23 AM
                                        • proxneo
                                          Recapping Sony ICF-SW55 - verifying cap values
                                          by proxneo
                                          Dear reader
                                          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                          At the moment, I have selected replacements based on the following list of values:
                                          3 x 470uF 10VDC
                                          3 x 4.7uF 35VDC
                                          4 x 47uF 50VDC
                                          8 x 22uF 6.3 VDC
                                          1 x 220uF 6.3VDC
                                          5 x 100uF 6.3VDC
                                          Which...
                                          06-21-2023, 12:38 AM
                                        • rashidjafar
                                          Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                                          by rashidjafar
                                          I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                                          Values for :-
                                          PC43 : Capacitor [3x1.5mm]
                                          PL7 : Inductor [2x1mm]
                                          PC39 : Capacitor [1x0.5mm]
                                          Any ideas would be appreciated.
                                          I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                                          08-07-2025, 05:10 PM
                                        • mkdj
                                          MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                          by mkdj
                                          About me, my goal and the equipment I (don't) have:
                                          I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                          About my issue and my goal:
                                          A friend of mine has a MacBook Air M1 A2337 that does not...
                                          04-03-2025, 08:28 AM
                                        • Kobok
                                          Different (lower) resistor values on PCB?
                                          by Kobok
                                          Dear Alls,
                                          For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                                          09-19-2022, 07:30 AM
