asus b75m-plus PSU turns on but no POST. Reset button starts it ?
  • ebj423
    • Jun 2022
    • 6
    • Philippines
    Posted Today, 07:34 PM
    , Hi! In the normal startup process, my pc's power led will turn on, the hdd led will flash brightly for a moment, then beeps once and you would know that everything is starting up fine. But recently, it will just flash dimly(sometimes too dim to see) and then nothing, no beep to show it is posting but the psu is on and all fans/hdds/peripherals/usb are on, even the lan port is flashing. Luckily, I discovered that pressing the reset button after the power button will initiate the post (the hdd led will flash brightly, beeps once and everything starts up fine), but you have to press the reset button, very tiringly, a lot of times.
    I checked the voltages; (+3.3v)+3.38v, (+5v)+5.19v, (+12v)+12.15v, (-12v)-11.8v, (ps_on) +4.55voff/0v on and running, (power_ok) 0v off/ +5.18v on and running and (+5vsb) +5.22v off/ +5.18v on/ +5.14v running. Tried the rams one at a time, all are fine. Reset the cmos by removing the battery, shorting the battery contacts for a minute and pressing the power button for about a minute also. Removed the board from the chassis in case of short and swapped the psu twice, all with the same result. That only leaves me with the mobo or cpu as suspect but I'm at a loss where to start.
    Can someone please tell me if I missed something or where to troubleshoot if it's the motherboard? And does anyone have a schematic for an asus b75m-plus motherboard? The nearest model I can find is a b75m-a.
    Thank you.
    OS - win7 ultimate
    CPU - i3-3240
    GPU - internal
    MB - asus b75m-plus
    RAM - 2 x 4gb hyperx, 2 x 4gb team elite
    BIOS - updated to latest a few yrs ago
    DRIVERS - updated to latest
    PSU - generic
    CASE - skywalker
    some other symptoms:
    1. switching on avr automatically turned on psu without pressing the power button but then turns off after a few seconds (happened twice)
    2. very rarely hangs (about 3 times) not on games but just on browser with a couple of tabs open.
    3. the notification icons in lower right taskbar may be corrupted (maybe because of the improper starting), some are blank.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: PSU turns on but no POST. Reset button starts it ?
    Reflash BIOS
    • ebj423
      • Jun 2022
      • 6
      • Philippines
      Preparing a usb to reflash the bios "IF" it posts. I followed your link and I don't know what to do. Btw, I'm using the latest boardviewer beta and all I can figure our so far are parts and their pin designations, and "net" shows their connections.
      Thank you very much for your reply!
      • ebj423
        • Jun 2022
        • 6
        • Philippines
        Just downloaded rev.1.02 diagram of my mobo but sadly not the one I need. Still looking for 1.01 and 1.00.
        • ebj423
          • Jun 2022
          • 6
          • Philippines
          Sorry for the delay. Just got it to POST and ran EZ flash utility after which pc resets and doesn't post again. Sadly I'm back to square one.
          Any other suggestions please?
          • sheffieldyorky
            ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
            by sheffieldyorky
            Hey there people
            While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
            This is what I tried, but not in any order.
            Google
            YouTube
            BIOS
            Command Prompt (administrator privileges)
            On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
            10-25-2025, 02:22 AM
          • kotel studios
            ASUS M5A78L-M LX - PWR button works sometimes, CPU stuck in reset
            by kotel studios
            Firstly I'd like to apologize if this was posted in the wrong forum (I'm new here )
            Recently I got an ASUS M5A78L-M LX board in a scrap lot. Saw one broken cap which I've replaced. No broken traces and missing components. While soldering a new cap a bit of solder got onto components bellow SB (opposite of the two lythic caps). Didn't see it and powered the board on.
            I was greeted with it not starting. Came back to it a day later and shorted the PS_ON with GND to force it on. It sprung to life but with CPU stuck in reset (it was an FX 4600 I believe). Thats when I saw the...
            12-14-2024, 10:48 AM
          • Daniel Larsson
            Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
            by Daniel Larsson
            My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
            I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
            During these seconds the function button is not working...
            08-13-2025, 10:29 AM
          • pingaroon
            Dell E6540 starts with Jack, but not with Power Button
            by pingaroon
            Hi guys,
            I have an LA-9412P Dell E6540 (lvds) MB with the following issue - the board starts up (and operates normally) when the charger jack is plugged in but pressing the power button has no effect whatsoever. The power button is onboard (ie not a separate board with cable)
            This is what I know:
            -The bios battery is good (3v)
            -The board starts with the power jack even when the bios battery is connected (not normal). With the date / time etc set up and saved, it still starts when the jack is connected.
            -The power button measures 3.3v and shorts...
            03-24-2021, 05:40 PM
          • sli4
            Original NES power issues
            by sli4
            I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
            I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
            Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
            On the big blue connector I get...
            11-28-2024, 12:52 PM
