Abit SE6 recapping using 10mm caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Yet another capacitor-related commonly failed Abit board, the SE6... This board has a quantity of 18 - 1500uF 6.3v caps that fail. I've seen some with JPCON and others with Teyah.
    Ok, when at all possible, I don't recap a board using 8mm caps. In some cases, the use of 10mm replacement caps is just not possible, but this board is not one of those. Yes, the 10mm caps fit a little tightly, but in the end, it will look and work perfectly.
    I've had a few emailing me about 10mm caps in place of 8mm, mostly associated with the BP6, which I always use 10mm caps in. This board is no different.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • black6host
    Replacement caps for Samson Resolv studio monitor 65A Amp board.
    by black6host
    Good day!
    I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
    I'm going to replace the caps and I'll be the first...
    02-06-2024, 08:22 PM
  • Noodneek
    Replacing all the caps on the BenQ SW2700pt's power board didn't help...
    by Noodneek
    My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
    I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
    08-30-2024, 12:52 PM
