HP 840 G5 EndPoint Security Controller Problem
  • abdoelhosseiny@aol.com
    • Jun 2020
    • 37
    • UEA
    please Help Me ... Hp 840 G5
    HP EndPoint Security Controller Problem
  • hoaca388
    Badcaps
    • Jan 2022
    • 12278
    Re: HP EndPoint Security Controller Problem
    Originally posted by abdoelhosseiny@aol.com
    please help me ... Hp 840 g5
    hp endpoint security controller problem
    bios
    • rediii
      h???, spurrrn
      • Mar 2018
      • 499
      • somewhere in europe
      Originally posted by hoaca388
      hey hoaca, maybe you can help me or give some instructions how to eliminate this error. i'm very grateful, thanks. roms are attached, machine works fine beside of this stupid failure
      • peste
        • Dec 2016
        • 13451
        • ROMANIA
        try this first..
        Enter the bios and restore the security settings to defaults and restart the laptop
        • rediii
          h???, spurrrn
          • Mar 2018
          • 499
          Originally posted by peste
          try this first..
          did it at first, error remains, but thanks.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12278
            Impossible because I failed.
            • rediii
              h???, spurrrn
              • Mar 2018
              • 499
              outch. okay, why though? what i heard is, that there is "patch", but it costs around 20 $ or so... can't find anything about this method. do you have a clue?
              • hoaca388
                Badcaps
                • Jan 2022
                • 12278
                Have you tried editing the 16MB file ?
                • rediii
                  h???, spurrrn
                  • Mar 2018
                  • 499
                  i didn't edit anything, but the 32 mb bios for clear me. sadly the bios came from another mainboard that was fried. the repaired board didn't had the rom ics on it... so i had to take the others. since then i encounterd this error...
                  • rediii
                    h???, spurrrn
                    • Mar 2018
                    • 499
                    i would like to extract the bios from the original hp bios side, without dmi info, but they changed something, so the extraction isn't possible anymore?
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12278
                      Flash this file, trying go into bios setting on the first boot for disable all the security options.
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 499
                        okay, give me a sec. thank you
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 499
                          still there
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12278
                            Re: HP 840 G5 EndPoint Security Controller Problem
                            Deadlock
                            • rediii
                              h???, spurrrn
                              • Mar 2018
                              • 499
                              Deadlock
                              thank you very much
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12278
                                thank you very much
                                Try again. Flash both files.
                                • rediii
                                  h???, spurrrn
                                  • Mar 2018
                                  • 499
                                  oookay, will report. nice effort, though. if this will work, can you tell me what you've done? thank you so much
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12278
                                    Ofcause , hope it work.
                                    • rediii
                                      h???, spurrrn
                                      • Mar 2018
                                      • 499
                                      well, the error message disappeared!!! i'll lock the mpm and report! wow, very nice so far. what have you done? i tried to unlock the mpm via bcu, but access was denied... thank you for sharing your information :o)
                                      • rediii
                                        h???, spurrrn
                                        • Mar 2018
                                        • 499
                                        oh okay, you deleted the dmi info? did you manage to extract the original bios from the hp website?
                                        • kolebbk
                                          HP EliteDesk 705 G5 SFF (AMD) - Endpoint security controller problem
                                          by kolebbk
                                          Hi, I have a problem with my HP EliteDesk 705 G5 Small Form Factor computer on amd . Standard corrupted bios probably corrupted during the update. I have uploaded a clean dump from the manufacturer's website with the latest version but when I turn it on a message appears :
                                          HP Endpoint Security Controller problem
                                          there is a problem with the hp endpoint security controller on the unit
                                          I tried restoring the bios security to factory defaults after the first switch-on because this helps with intel-based laptops. Here unfortunately this did not help. Does anyone have...
                                          09-04-2024, 12:44 AM
                                        • fede77
                                          Problem with the HP Endpoint Security Controller - HP ProBook 450 G8
                                          by fede77
                                          Notebook HP ProBook 450 G8
                                          ProdID 2K8L1LT#AC8
                                          Mother: DAX8QAMB8D0 REV D
                                          The device had bootloop issues. I reprogrammed the EC BIOS and the main BIOS, extracted from an HP 440 G8 with the same motherboard, and I was able to start the device. However, every time I turn it on, I get the error 'There is a problem with the HP Endpoint Security Controller in the unit.' I tried disabling several security options in the BIOS, but the error still appears. Additionally, when I attempt to update the BIOS, both BIOS chips get corrupted again....
                                          03-10-2025, 07:12 AM
                                        • lamonde
                                          850 G6 Endpoint Security Controller Problem
                                          by lamonde
                                          Hi! Please help with Endpoint Security Controller Problem, sending old not working dumps. Thankyou
                                          and there is no soud after flashing new bios, may be have some solutions?
                                          ProdID: 4YD62AV
                                          SN: 2TK9500V8X...
                                          01-15-2025, 09:31 AM
                                        • biednybelfer
                                          HP HP MT45 Mobile Thin Client Endpoint Security Controller Problem
                                          by biednybelfer
                                          After removing the password I get an error "There is a problem with hp endpoint security controller on the unit". I read that I need a modified BIOS. There are 3 ISP on my board.
                                          Mainbard model:6050A3044201-MB-A01 (A1)​
                                          Serial Number: 5CG0275ZLV
                                          (I'm not allowed to upload files with the extension bin, so I upload zip)...
                                          10-05-2024, 05:04 AM
                                        • Voyager65
                                          HP 800 G6 Deskop Mini - Endpoint Security Controller Problem
                                          by Voyager65
                                          I got a used HP and see this well known HP Endpoint Security Problem Screen. Someone seems to have removed the password and reflashed the bios with (maybe) a wrong serial etc.. I was able to read and write with my programmer a new bios onto it - same problem. I tried a downgrade, same.
                                          I did password removal wir rcunlocker on several other machines without any problem. But this one is/was killed before. Appreciate any help.
                                          SN: 8CC1120Z0V
                                          PN: 8WY18AV
                                          Bios Dump:
                                          Thanks a lot...
                                          01-13-2024, 04:58 PM
